B16 swapped but won't shift into reverse.
Old Jan 27, 2004 | 02:20 PM
crxtreme89h's Avatar
Default B16 swapped but won't shift into reverse.
I swapped in a B16 motor with Y1 LSD in my 89 HF. Everythings in and it runs, (needs tuned) but I can't get the sucker in Reverse. I have tried numerous ideas such as:
Shift into 1st then 2nd then Reverse
Shift into 1st then Reverse
Shift into 2nd then Reverse
Etc.......
It seems that the furthest it will shift is 4th and no further (let me clarify this, it will go into 5th gear). I thought, maybe shift linkage, but it's from Hasport and everyone I spoke with said that's not the case. Some said possible reverse is shot. When does that ever happen?
I checked the linkage under the car and everything is in place. Every other gear works just fine.
Tell me what you guys think. Personal experiences with this issue?
Thanks in Advance!
-Damon
Modified by crxtreme89h at 11:42 PM 1/27/2004
Old Jan 27, 2004 | 02:23 PM
89 CRX SI's Avatar
Default Re: B16 swapped but won't shift into reverse. (crxtreme89h)
maybe your pin that holds the shift linkage on your tranny is like so worn that its got so much play it cant get past the turning movment of going into the 5th reverse area..
does it go into 5th?
otherwise maybe the linkage is bent in the mail
talk to hasport theyll help you
Tory
Old Jan 27, 2004 | 02:41 PM
Default Re: B16 swapped but won't shift into reverse. (89 CRX SI)
1st thru 5th I have no problems. The linkage looked and still looks fine. See that's what I thought is that if I can get into 5th then I should be fine. But when I go straight from 5th down into Reverse it's like the shifter just kinds curves into 4th. Almost like there is no Reverse. I have tried pushing hard to the right and down slowly letting out the clutch to maybe pop it into reverse but that was a no go either. The sad thing is that my Reverse lights don't even work so I can't have someone sit behind my car to see if the lights even come on for one second. You know, like if I am almost there, the lights should come on. Frustrating stuff!
Old Feb 10, 2004 | 10:44 AM
Anyone else have any takes on the situation?
Old Feb 10, 2004 | 10:50 AM
manson's Avatar
did you put a new clutch or flywheel in when you did the swap?
Old Feb 10, 2004 | 10:58 AM
EL Vap133's Avatar
Have you tried adjusting your clutch cable?
Old Feb 10, 2004 | 11:00 AM
Default Re: B16 swapped but won't shift into reverse. (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mansonclubpuir &raquo;</TD></TR><TR><TD CLASS="quote">did you put a new clutch or flywheel in when you did the swap?</TD></TR></TABLE>
No new clutch or flywheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried adjusting your clutch cable? </TD></TR></TABLE>
No, I will try that. Thanks for the idea man!
itismejoshd
25
Sep 25, 2007 05:16 AM
CRX2112
Nov 14, 2006 12:04 AM
sohc prelude
Feb 26, 2006 07:26 PM
vtekthis
Feb 8, 2004 02:47 PM
