tune up
Old Jan 27, 2004 | 11:34 AM
ieatrice's Avatar
Default tune up
sup guys, i have 107k on my 95 si hatch (d16z6) and i think it's time for an oil change. just to learn, i want to do the tune up myself? what else should i change besides the motor oil? btw, what oil should i get???
Old Jan 27, 2004 | 11:37 AM
skip.two's Avatar
Default Re: tune up (ieatrice)
um.
bleed the brakes.
change the coolant.
timing belt.
somebody add to the list...
Old Jan 27, 2004 | 11:39 AM
976's Avatar
976
New User
spark plugs
spark plug wires
PCV valve
dis. cap & rotor
timing belt
other belts if needed
oil & filter change
tranny fluid change
carbon build-up clearner (if desired)
fuel injector cleaner (if desired)
I'm forgetting a lot of stuff I have a feeling...
E-brake or Handbrake's Avatar
Default Re: tune up (jL iLLuZiOnz 9)
spark plugs & wires
brake pads
check your local automotive listings in your mailbox to see what they offer.
they usually list the things they'll perform for a certain amount. happy tuning.
Old Jan 27, 2004 | 11:41 AM
skip.two's Avatar
Default Re: tune up (EJ1Z6)
haha i left out a lot. its too frickin early in the morning. i should go back to bed, school sucks
Old Jan 27, 2004 | 11:42 AM
Gerbilo's Avatar
you'll need an oil filter for changing the oil too, don't forget.
check air filter
tire pressure
fuel filter
Old Jan 27, 2004 | 11:45 AM
elevatethis's Avatar
haha how he said that, it sounds like he hadn't changed the oil in 107k miles. But I'm assuming you've changed it due to the fact that you've made it to 107k.
Oil Change:
4 qts 5w30 motor oil of your choice
honda oil filter from the dealer
new 12mm drain plug washer if you want to be ****.
ieatrice's Avatar
thanks for all the suggestions guys! i knew i can count on fellow HT'ers for help.
Old Jan 27, 2004 | 11:49 AM
ieatrice's Avatar
Default Re: tune up (elevatethis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elevatethis &raquo;</TD></TR><TR><TD CLASS="quote">
aw.. i got 10w30.. is that cool? or should i return it and get the 5w30
Old Jan 27, 2004 | 11:51 AM
JimmyAtlantis's Avatar
Don't forget your air filter too!
Old Jan 27, 2004 | 12:00 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
castrol full sythetic 10w30.....good but expensive....you get what you pay for...that is what i say...
Old Jan 27, 2004 | 12:02 PM
Gerbilo's Avatar
Default Re: (dgonzals)
on a similar topic, anyone have experience whether the high milage motor oils are any good or worth the money?
ieatrice's Avatar
Default Re: tune up (JRI94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget your air filter too!</TD></TR></TABLE>
i almost forgot!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice &raquo;</TD></TR><TR><TD CLASS="quote">
aw.. i got 10w30.. is that cool? or should i return it and get the 5w30</TD></TR></TABLE>
matters most if you live in 50/50 climates--ie; really cold one season then just really really hot another season.
I think you're a-ok
Rikaro
Nov 23, 2008 06:20 PM
KrazyDawg
Mar 18, 2008 04:39 PM
Civicta
Feb 10, 2006 07:51 AM
BoostFrenzy.com
Apr 8, 2004 08:09 AM
VtechMixedKorean
Dec 28, 2002 01:11 PM
