tune up
tune up
sup guys, i have 107k on my 95 si hatch (d16z6) and i think it's time for an oil change. just to learn, i want to do the tune up myself? what else should i change besides the motor oil? btw, what oil should i get???
New User
Re: tune up (ieatrice)
spark plugs
spark plug wires
PCV valve
dis. cap & rotor
timing belt
other belts if needed
oil & filter change
tranny fluid change
carbon build-up clearner (if desired)
fuel injector cleaner (if desired)
I'm forgetting a lot of stuff I have a feeling...
spark plug wires
PCV valve
dis. cap & rotor
timing belt
oil & filter change
tranny fluid change
Re: tune up (jL iLLuZiOnz 9)
spark plugs & wires
brake pads
check your local automotive listings in your mailbox to see what they offer.
they usually list the things they'll perform for a certain amount. happy tuning.
brake pads
haha how he said that, it sounds like he hadn't changed the oil in 107k miles. But I'm assuming you've changed it due to the fact that you've made it to 107k.
Oil Change:
4 qts 5w30 motor oil of your choice
honda oil filter from the dealer
new 12mm drain plug washer if you want to be ****.
Oil Change:
Re: tune up (elevatethis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elevatethis »</TD></TR><TR><TD CLASS="quote">
aw.. i got 10w30.. is that cool? or should i return it and get the 5w30
Re: tune up (JRI94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 »</TD></TR><TR><TD CLASS="quote">Don't forget your air filter too!</TD></TR></TABLE>
i almost forgot!
i almost forgot!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice »</TD></TR><TR><TD CLASS="quote">
aw.. i got 10w30.. is that cool? or should i return it and get the 5w30</TD></TR></TABLE>
matters most if you live in 50/50 climates--ie; really cold one season then just really really hot another season.
I think you're a-ok
I think you're a-ok
Rikaro
11-23-2008 06:20 PM
