still prob with chipped ecu
Old Jan 27, 2004 | 09:29 AM
Jagolas's Avatar
Default still prob with chipped ecu
ok now i cut the j1 jumper, but now i still get the same prob of 4k rev limit and check engine light. it is possible for me to re solder the ecu and get it to work?
and on the bottom side it looks like crap, the j1 jumper soldered together on the back so should i just move it were they are not touchin? thanks
Old Jan 27, 2004 | 10:21 AM
tgreaves's Avatar
Default Re: still prob with chipped ecu (jagolas)
Start from the top.. What ecu is this, Auto or manual, The low rev limit could be either its in limp mode or its hitting a cold rev limit.. Who chipped the ecu and what else did they do to it..
Old Jan 27, 2004 | 10:55 AM
Jagolas's Avatar
Default Re: still prob with chipped ecu (tgreaves)
p28 manual yeah i chipped it (shouldn't have) and i think it's in limp mode. that's what i was told last night. then i was told to correct it to norm cut j1 jumper. i did and that didn't help.
Old Jan 27, 2004 | 11:15 AM
prestonpark's Avatar
ur ecu fuked up
if u cut j1 one it should set it to stock
but i think u messed up he whole board
Old Jan 27, 2004 | 11:26 AM
tgreaves's Avatar
Default Re: still prob with chipped ecu (civic2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2003 &raquo;</TD></TR><TR><TD CLASS="quote">ur ecu fuked up
but i think u messed up he whole board</TD></TR></TABLE>
Thats my guess.. I would look for another p28 and try to find a chipped one or get a pro to chip it.. Might want to try desoldering the socket and try it with j1 cut..
Old Jan 27, 2004 | 11:35 AM
Burke's Avatar
Banned
are you sure j1 isnt still closed on the other side cause of excess solder??
Old Jan 27, 2004 | 11:48 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
get a new one....should solve the problem...
Old Jan 27, 2004 | 02:27 PM
Katman's Avatar
take some nice clear pictures of your ecu if you can, and post 'em. Some of us are ecu reprogrammers (like me) and can look at your work and see if you F'd something up or not.
Old Jan 27, 2004 | 04:45 PM
Jagolas's Avatar
Default Re: still prob with chipped ecu (Katman)
thanks for all the help but i found out it is f'd up so i can get another for like 50 or one for 100 from some local junkyards. goin to do a b18b swap in a month or 2 so i will just get an oe. thanks again
TravisCadello
Oct 22, 2008 07:25 AM
SpdKilz23
Sep 28, 2008 08:51 AM
blackteg
May 12, 2004 07:31 AM
bearboy80
20
Sep 17, 2003 02:20 PM
johnzm
Sep 12, 2002 06:36 PM
