oil on plug threads
Old Jan 27, 2004 | 07:54 AM
XenoPhobe's Avatar
Default oil on plug threads
so, the oil is on the threads, not a bunch, but some. eventually, the plug gets fouled. i've changed the valve cover gasket, but no luck. does this mean i got bad piston rings? if so, what kinda problems will this cause if I let it go til summer? anyone experienced this?
96 Civic HX
Old Jan 27, 2004 | 08:00 AM
B18C2_sedan's Avatar
Default Re: oil on plug threads (XenoPhobe)
did you change the oil seal around plug holes. Not just the gasket
Old Jan 27, 2004 | 08:17 AM
XenoPhobe's Avatar
Default Re: oil on plug threads (B18C2_sedan)
i got those seals with the valve cover gasket, but I haven't changed them, cause they seemed like they were not coming out. so, what's the best way to get em out? just poke em out with a flathead?
Old Jan 27, 2004 | 09:42 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XenoPhobe &raquo;</TD></TR><TR><TD CLASS="quote">... just poke em out with a flathead?</TD></TR></TABLE>Yeah, but be careful not to scratch the grooves they sit in. You're gonna throw away the old rubber rings so it's ok to butcher them. Try not to scratch the metal.
They get hard when they're old. They can look OK but still not seal because they're not rubbery.
Old Jan 27, 2004 | 01:20 PM
suspendedHatch's Avatar
Default Re: oil on plug threads (JimBlake)
I have the same problem. I replaced the valve cover gasket and the spark plug gaskets. I still have the oil. I was told to get some "honda gasket" and reinforce the spark plug gaskets, but I haven't done that yet.
DiRty Dc4
Jan 29, 2013 05:23 PM
rwasmund
Oct 19, 2008 11:50 AM
rjmancia
15
Sep 13, 2008 08:57 AM
project midnight
Sep 17, 2006 09:43 PM
hYpE-R-29
May 13, 2003 06:16 PM
