My boosted lude... Turbo selection question
In the process of boosting my 98 prelude. I know all about the weak ringlands and sleeve problems. I've heard I'll be fine with 7psi and i heard i wont be fine at 7psi. I am getting it resleeved and everything next winter. So i am going to risk it. . with that out of the way
The question
I am going to be buying a TO4E turbo. its pretty big with A compressor AR of .60 and a exhaust of .60... Is this going to cause more wear on my engine than a smaller turbo at the same psi? I know the to4e is going to have more CFM but does that matter when it comes to ringlands and sleeves?
Thanks
The question
Thanks
Good question...
https://honda-tech.com/zerothread?id=728240
As far as the exhaust turbine specs, are you sure it is not a t3 .63 a/r?
This turbo should be safe when ran with 7psi and an adequately sized intercooler.
Im sorryI got confused. this is the size of the turbo (57 trim T04E, stage 3 turbine .63 AR capable of 400 hp) Thatw what he sent me
ehh intercooler size won't really play since 99% of us run gigantic intercoolers for our setups, anyway....... just run it rich, you'll be fine
