i called up ms cleo and she said my plugs didnt look too good
Old Jan 26, 2004 | 01:30 PM
nevin's Avatar
Default i called up ms cleo and she said my plugs didnt look too good
so i decided to check them.
7 psi, 4-5deg base retard, mid 11 afr. sorry about the lighting i was using my camcorder and couldnt tell what i was shooting.
Old Jan 26, 2004 | 02:08 PM
nevin's Avatar
oh yea so what do you guys think
Old Jan 26, 2004 | 02:11 PM
swlabhot's Avatar
Default Re: (nevin)
I don't see anything wrong?
Old Jan 26, 2004 | 02:35 PM
SKDRCR's Avatar
Default Re: (swlabhot)
shouldn't they be a little darker?
you wanna run lean if your boosting right?
Old Jan 26, 2004 | 02:39 PM
TravSi's Avatar
Default Re: (SKDRCR)
yea if you want your motor to blow...replace that statment with the word rich and yur good to go......u want to be a lil rich with boost lil extra fuel always helps
Old Jan 26, 2004 | 02:43 PM
SKDRCR's Avatar
Default Re: (TravSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravSi &raquo;</TD></TR><TR><TD CLASS="quote">yea if you want your motor to blow...replace that statment with the word rich and yur good to go......u want to be a lil rich with boost lil extra fuel always helps </TD></TR></TABLE>
on me that's what i mean't to say, darker=richer
Old Jan 26, 2004 | 02:47 PM
Chillinit's Avatar
plugs look good man...how many kilometers/miles do u have on them??
Old Jan 26, 2004 | 02:50 PM
nevin's Avatar
I was thinking they look a little lean, maybe those specs are detonation? I listen for detonation like a paranoid crackhead and I couldnt hear any but my car is so loud its hard to tell.
I dont feel confident in my plug reading skills, can anyone else comment. thanks
Old Jan 26, 2004 | 02:52 PM
nevin's Avatar
Default Re: (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">plugs look good man...how many kilometers/miles do u have on them?? </TD></TR></TABLE>
I have drove on them for less than a week. I have only hit full boost and held it to redline less than 5 times. Those pictures are after a 4th gear pull to 6500 and then turning the car off.
Old Jan 26, 2004 | 02:54 PM
Tad's Avatar
Tad
those plugs look brand new man.
but yeah, if you are boosting,
rich is good. But personally I would MUCH MUCH MUCH rather gauge that using a proper measuring device, like a wideband o2 sensor, than by looking at the color of my spark plugs.
the plugs look in good condition, and thats what matters.
Old Jan 26, 2004 | 03:05 PM
nevin's Avatar
Default Re: (Tad)
wb was reading mid 11s, egt was about 1450.
Old Jan 26, 2004 | 04:56 PM
egturbo's Avatar
Default Re: i called up ms cleo and she said my plugs didnt look too good (nevin)
i think miss cleo is talking about ur butt plugs haha.. jk.
Old Jan 26, 2004 | 04:58 PM
danl's Avatar
Banned
Default Re: (nevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin &raquo;</TD></TR><TR><TD CLASS="quote">wb was reading mid 11s, egt was about 1450. </TD></TR></TABLE>
Those plugs look pretty damm awsome IMO. I'd like to see a little more brown on the center insulator but that may very well be the lighting. The ground strap doesen't look like its getting hot or anything however. It kinda looks like you pulled off the highway and parked the car. Some hondas seem to like to run quite lean on the highway, possibly for lower emissions and gas milage.
The threads look to be darkened 2-3 rings up. This indicated a good heat range for overall driveability. Typically one shoots to darken the first two threads and when you start darkening the third you may want to try a colder plug and see how that works out. I really don't like to see more than 4 threads darkened, that is much too hot in my opinion.
You can't really tell if you are running lean in boost or detonating in boost unless the plugs were pulled right after a strong pull. This is this bad for your turbo (should let it cool down). Your a/f ratio means that you have plenty of fuel. Your EGT are good, but timing plays a major role in that.
Everything looks good. Just curious, what is your timing at under boost from 4000rpm's to redline?
Old Jan 26, 2004 | 04:59 PM
racinskittle's Avatar
Default Re: i called up ms cleo and she said my plugs didnt look too good (egturbo)
those plugs look great. I always look at the plugs like a psycho too.
That and I do compression tests after EVERY time I drive. I get SOOOO paranoid lol. I know exactly what you mean. 175-180 across all 4
Old Jan 26, 2004 | 07:19 PM
Bailhatch's Avatar
Default Re: i called up ms cleo and she said my plugs didnt look too good (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">those plugs look great. I always look at the plugs like a psycho too.
That and I do compression tests after EVERY time I drive. I get SOOOO paranoid lol. I know exactly what you mean. 175-180 across all 4 </TD></TR></TABLE>
LOL you are crazy, i knew it. and those plugs look pretty good
Old Jan 26, 2004 | 07:20 PM
B18bEK's Avatar
i have the same paranoia, just don't go to the extreme of actually doing the compression check oh ya, the plugs look pretty normal .
Old Jan 26, 2004 | 07:25 PM
Suprdave's Avatar
Default Re: i called up ms cleo and she said my plugs didnt look too good (B18bEK)
The location of the 'color' on the ground strap is determined by ignition timing.
Those plugs look fine to me...
Old Jan 26, 2004 | 08:18 PM
nevin's Avatar
Thanks guys
edit: Im just scared cause this is the same fuel setup that I was using when I spun a bearing. The motor was very old and abused though.
Old Jan 26, 2004 | 09:06 PM
D@nnY's Avatar
get ngk7s they disapate heat better.. are those 6s?
Old Jan 27, 2004 | 06:57 AM
nevin's Avatar
Default Re: (GSRT37)
bkr7e
Old Jan 27, 2004 | 07:02 AM
espanol's Avatar
Default Re: (nevin)
try the R5671A-9. stock #5238.
Old Jan 27, 2004 | 07:03 AM
KrautFed's Avatar
Default Re: (nevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin &raquo;</TD></TR><TR><TD CLASS="quote">bkr7e</TD></TR></TABLE>
Here's mine. (20psi + 50 shot + lots of timing )
Old Jan 27, 2004 | 07:56 AM
danl's Avatar
Banned
Default Re: (KrautFed)
KrautFed, those plugs look AWSOME! Doubt you have things working great. I'll try to get some pics up of my eclipse at 25 psi with 5K on the plugs, pump gas as well.
ITR.#1446
May 29, 2008 09:19 PM
ifIexplode
Apr 16, 2008 08:53 PM
handa
21
Apr 2, 2005 11:43 PM
Boost Addict
May 19, 2004 08:04 PM
roydogg
Dec 23, 2003 11:23 AM
