hf and dx cranks.. Whats the difference
Old Jan 26, 2004 | 10:16 AM
tgreaves's Avatar
Default hf and dx cranks.. Whats the difference
Anyone know what the difference is between the 88-91 crx dx and 88-91 crx hf crankshafts.. They have different part numbers but I dont see what the difference could be between them..
Old Jan 26, 2004 | 10:44 AM
owen_the_soyboy's Avatar
Default Re: hf and dx cranks.. Whats the difference (tgreaves)
I know some year HF crankpulleys are smaller or lighter, forgot which, but it may be a different end bolt or end diameter or something to that effect?
Old Jan 26, 2004 | 11:13 AM
tgreaves's Avatar
Default Re: hf and dx cranks.. Whats the difference (owen_the_soyboy)
Hmm.. Im just trying to figure out if D15B2 rods and pistons will go into a D15B6(hf) block with the hf crank..
Old Jan 27, 2004 | 01:44 AM
Mista Bone's Avatar
D Tranny Guru
won't work.
D15 16V uses 45mm rod bearings
HF uses 42mm rod bearings
Also the HF crank is lighter, doesn't have the counterweights.
Old Jan 27, 2004 | 05:47 AM
tgreaves's Avatar
Default Re: hf and dx cranks.. Whats the difference (Mista Bone)
****.. Will d15b2 rods, pistons, and a crank fit into the d15b6 hf block..
Old Jan 27, 2004 | 12:11 PM
Mista Bone's Avatar
D Tranny Guru
yes, the main bearings are the same size.
FYI Bisimoto ran a D15B6 block to 10.77 in the 1/4 mile.
Old Jan 27, 2004 | 12:36 PM
tgreaves's Avatar
Well then the only difference between the b2 and b6 bare block is the engine code stamp on the outside of the block..
jhrusk
Sep 30, 2008 04:01 AM
dod
Mar 20, 2006 08:15 PM
onePOINTsix
May 18, 2004 12:49 PM
tgreaves
Dec 16, 2003 01:59 PM
bluebullet
10
Jun 16, 2002 06:58 PM
