Damaged crank pulley questions.
Old Jan 26, 2004 | 09:12 AM
jerseydevil's Avatar
Default Damaged crank pulley questions.
My gsr swap came with a damaged crank pulley. The outer most edge of the pulley what holds the power steering belt had broken off in multiple places. We weren't using power steering my del sol so we ground off the rest of the outer lip on the pulley with a die grinder and smoothed it all out. My local engine shop said not to worry about the pulley.
Should I worry about this pulley causing problems at high rpm? I read else were on here that the stock pulleys are not balanced and just use a rubber spacer to dampen the crank. So if the outer ring of metal on the pulley is damaged it doesn't matter??
I'm asking because we did a full rebuild on the gsr about 1500 miles ago. It had been running real strong, never smoked at all, didn't burn any oil. I never ran the engine about 5k during the break in and didn't go into vtec unil after 600 miles. We'll I made my first pull to the redline a couple of days ago and two days later the front main seal by the oil pump started leaking pretty bad. Lost a quart in 25 miles doing 70mph. Just wondering if the pulley at 8k rpm damaged the seal.
Old Jan 26, 2004 | 09:15 AM
mmuller's Avatar
Mad Scientist
Default Re: Damaged crank pulley questions. (jerseydevil)
i had the same problem and just for piece of mind i changed it. But you could take it to a machine shop and get it balanced
Old Jan 26, 2004 | 10:46 AM
owen_the_soyboy's Avatar
you shoulda had the pulley balanced.
out of balance parts are a maaajor issue for oil pump failure.
oil seal though? I dunno.
Old Jan 27, 2004 | 03:25 AM
Does the oem gsr pulley come rotationaly balanced?
Old Jan 27, 2004 | 06:12 AM
Default Re: (jerseydevil)
I would guess that all honda ones DO come balanced, but I hear the CTR N1 is not balanced from the factory though.
Old Jan 27, 2004 | 06:31 AM
CHEETAH's Avatar
Default Re: (owen_the_soyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy &raquo;</TD></TR><TR><TD CLASS="quote">I would guess that all honda ones DO come balanced, but I hear the CTR N1 is not balanced from the factory though.
balancing on the pulley is different that dampening. the OEMs are all dampened and balanced (notice those lil craters in them on the sides) ... the N1 is differnet alloy and is not dampened. Honda and Spoon takes their motors upwards of 10Krpm with the N1 in endurance testing so for some reason it works. Also, I've never seen damage from the N1 CTRs, but have seen couple Turbo motors from using the older Unorthodox aluminums.
greg
spddmn124
Apr 6, 2005 10:04 AM
littledan
Aug 12, 2003 08:57 AM
mdpalmer
Jul 27, 2003 03:10 PM
satan_srv
Aug 21, 2002 12:03 PM
Bnjmn
Jul 7, 2002 02:17 PM
