WTF? Check out my motor. What is this plug for?
Old Jan 25, 2004 | 09:59 PM
THE GAME IS THICK's Avatar
Default WTF? Check out my motor. What is this plug for?
I am doing a longblock swap on my integra and i bought a motor from hmotorsonline. As i was changing the timing belt, water pump, and tensioner i notice that my old engine had a wire under the oil pump that my new motor from hmo didnt have. will i throw a CEL code if this is not pluged in? what exactly is this? what can i do now?
old engine B18B-1997 integra LS "auto" if that matters
new engine JDM B18B also obd-2 from what im told from the guys at hmo
also if you look at the new motor theres all that black crud around the oil pan. Is this normal? maybe an oil leak?
Please help, thanks in advance
-Brandon
Old Jan 25, 2004 | 10:22 PM
boostn420's Avatar
Default Re: WTF? Check out my motor. What is this plug for? (igotsol!)
That is a crank shaft fluctuation sensor. Its for obd2, if the old one has it the new one needs it. It mounts to the pump so you need to swap the oil pumps to use it. With out it you will throw a code.
Old Jan 26, 2004 | 07:42 AM
B18PoweredCivic's Avatar
Just do an obd1 conversion if you arent already...
Old Jan 29, 2004 | 10:25 AM
Default Re: (B18PoweredCivic)
thanks for the comments. im gonna swap it this weekend. Im fixing my sisters car and shes not a racer so im gonna leave it obd-2. does anyone know of any existing threads on how to change an oil pump? im too lazy to search right now.
Old Jan 29, 2004 | 12:22 PM
JDMCRX's Avatar
Default Re: (igotsol!)
Im japan they do not have the same OBD2 setup as us they use the crack trigure in the DIS only in North America.
d15vtecivic
Oct 14, 2007 08:20 AM
wwang924
Feb 23, 2006 11:10 AM
hondaracing1
Mar 31, 2004 08:44 AM
highmilehatch
May 18, 2003 06:22 PM
