Just bought a DC jdm 4-1 header..
I'm thinking about exchanging it at the shop i bought it from. I just bought it the other day, and i just found it that it's not the same as the jdm 4-1 which is oem! So i can't get a skidplate. I'm really afraid of how low it sits to the ground, i scrape a lot even when i go sideways on parking lot ramps. And i'm not really slammed (h&r sports, about 2" drop on my gsr, w/ 17's). My current set up is a AEM CAI, Apexi N1 catback.. i was planning to install the header along with a 2.5" carsound cat that i have not bought yet. What do you guys think i should do? Greddy 4-2-1? Help!!!!
I say use it.
Second they are not that exspensive comepared to others- So it will be like a test dummy
and you have a GSR- I have no knowlegde on those
how much of a lost of hp am i looking at w/ a dented header? I bought the ceramic one, should i exchange for the ss?
ive had mine for a year or more now...im lowered alot...ive only scraped it once...btw...you should have done research and known that the dc jdm 4-1 is not the same as the jdm 4-1
I will be getting that header soon, and I will be using a skidplate. People have just had the one for the JDM header welded or attached somehow to the header.
Maybe this helps
http://www.fastlineperformance.com/skidplate.htm
Maybe this helps
it wont scrape unless you really get onto something steep. Im on nuespeed sport springs, whcih are nearly identical to h&r sport springs. Ive hit my dc jdm only once, when i had to swerve into a driveway because some crap fell out of a truck in front of me. It wont scrape on driveways or speed bumps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ITR#0020 »</TD></TR><TR><TD CLASS="quote">I will be getting that header soon, and I will be using a skidplate. People have just had the one for the JDM header welded or attached somehow to the header.
Maybe this helps
http://www.fastlineperformance.com/skidplate.htm</TD></TR></TABLE>
yes.. you have to custom mount this piece in order to get it to work..
if you're going to do that though, might as well fabricate your own.. not too tough with some home depot supplies..
personally, I have the DC JDM 4-1, and am not worried about it at all.. and I had the skidplate on my old JDM 4-1.. I never hit anything with it..
Maybe this helps
alright thanks guys, i'm taking it down to a muffler shop right now.. to see if they can make me a custom cat and skidplate.
Insane Si Lum
Jan 19, 2004 01:06 PM
