car is shaking...
Old Jan 25, 2004 | 01:08 PM
kool168's Avatar
Default car is shaking...
the car is shaking during ideal, but normal when driving...
why does that happen?
Old Jan 25, 2004 | 01:09 PM
.RJ's Avatar
.RJ
Default Re: car is shaking... (SOL-R)
your tires are out of balance, or your inner CV is busted. most likely the tires.
Old Jan 25, 2004 | 01:41 PM
Cosworth's Avatar
How old is the car? When you say, it's shaking at idle, is it violent? Or, you just have a rough idle and can feel the idle fluctuation throught the steering wheel?
I've got no idea from your vague description, but maybe your ICV could be bad. Or, other million things... tell us more of the symptoms.
Old Jan 25, 2004 | 01:49 PM
baonest's Avatar
Default Re: car is shaking... (Cosworth)
does it shake like a polaroid picture....
hey ya?
Old Jan 25, 2004 | 02:48 PM
bbqman's Avatar
Has it been snowing in BC lately? if so , check for packed-in snow in the wheels. They will unbalance the wheel and make crazy vibrations.
I know, I live in Montreal and it snows here!
Old Jan 25, 2004 | 03:17 PM
Tweakmeister's Avatar
Default Re: car is shaking... (bbqman)
check your pressures first.
Old Jan 25, 2004 | 03:23 PM
kool168's Avatar
Default Re: car is shaking... (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">check your pressures first.</TD></TR></TABLE>
oh... sorry for my bad eng
not the problem from tires... the car is shaking only during idel (when the car is not moving)
when you sit in the car, and you will hear boom boom boom boom.... (the engine sound), but the car is shaking at the same time... boom boom boom...
the car is yr 2000 ITR have around 50000 km
will the engine bad?
Old Jan 25, 2004 | 03:26 PM
Kendall's Avatar
Could you have broken/cracked a motor mount? This seems like a good possibility.
Old Jan 25, 2004 | 03:41 PM
paRRRker's Avatar
Default Re: car is shaking... (baonest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">does it shake like a polaroid picture....
hey ya?</TD></TR></TABLE>
Old Jan 25, 2004 | 04:55 PM
RGoose18's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Could you have broken/cracked a motor mount? This seems like a good possibility.</TD></TR></TABLE>
Very good possibility, get it checked out
Old Jan 25, 2004 | 06:24 PM
vtec.dc2's Avatar
when this happen, does it idle at normal rpm? like 800-1100?
Old Jan 25, 2004 | 06:26 PM
Kendall's Avatar
Default Re: car is shaking... (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">when this happen, does it idle at normal rpm? like 800-1100?</TD></TR></TABLE>
It has a lot to do with the harmonic balance of the engine. Any crack will vibrate and shake if shaken at the correct harmonic frequency. It's very possible that your engine is putting off at idle, the correct harmonic frequency to cause turbulence in that particular crack.
Old Jan 25, 2004 | 06:27 PM
ZygSpeed's Avatar
Gone through any big puddles lately with an AEM intake ot something like that?
Old Jan 25, 2004 | 06:42 PM
Default Re: car is shaking... (zygspeed)
yeah sounds like a motor mount or a rod bearing
Old Jan 25, 2004 | 06:53 PM
MK Ultra's Avatar
Other, more mundane, possibilities are bad fuel or worn out ignition components.
Old Jan 25, 2004 | 07:04 PM
kool168's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Gone through any big puddles lately with an AEM intake ot something like that?</TD></TR></TABLE>
no... it's with a mugen intake.
idle normally
the car had an accident couple months ago, many things need to replace such as the whole front end, fender, suspension, header... also the transmission has a crack on it
jmanuel
Feb 24, 2015 04:25 AM
VTECwalka
Dec 22, 2012 09:05 PM
laxman0324
Aug 29, 2007 05:42 AM
92ehatch
22
Aug 5, 2005 03:03 PM
threatcon13
Apr 13, 2003 01:33 PM
