displacement calculator-- how much to bore H22
Old Jan 25, 2004 | 12:27 PM
H23vtecEG's Avatar
Default displacement calculator-- how much to bore H22
need to know what dissplacement i will get with 89mm and 90mm bore on an h22. also anyone here running 90mm on the street
Old Jan 25, 2004 | 12:28 PM
H23vtecEG's Avatar
Default Re: displacement calculator-- how much to bore H22 (H23vtecEG)
forgot to add that it will be running 18-20 psi.
Old Jan 25, 2004 | 12:42 PM
Wo-Nelly's Avatar
H22 89mm with stock stroke ~2257cc
H22 90mm with stock stroke ~2308cc
Old Jan 26, 2004 | 10:13 AM
buh_buh's Avatar
Default Re: displacement calculator-- how much to bore H22 (Wo-Nelly)
If you plan on going turbo, I wouldn't go with anything bigger than a 89mm bore. If something goes wrong I don't think you have any more room to bore and hone.
Old Jan 26, 2004 | 11:34 AM
chidoks's Avatar
Default Re: displacement calculator-- how much to bore H22 (buh_buh)
anyone know what the displacement would be with an h23 crank and 89mm? how about an h23 crank and 88mm?
Old Jan 26, 2004 | 11:49 AM
Daemione's Avatar
Default Re: displacement calculator-- how much to bore H22 (chidoks)
CC's =
<u>(.7854)*(bore^2)*(stroke)*(# of cylinders)</u>
1000
Old Jan 26, 2004 | 12:09 PM
MaxBoost's Avatar
New User
Default Re: displacement calculator-- how much to bore H22 (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">CC's =
1000</TD></TR></TABLE>
Wrong.
<u>(Pi)*(bore/2)^2*(stroke)*(# of cylinders)</u>
1000
85*89cc Motor
<u>3.1416*42.5*42.5*89*4</u>
1000
2020cc
Old Jan 26, 2004 | 12:16 PM
chidoks's Avatar
thanks...with an h23 crank and 89mm bore, its 2364cc's...srt-4 torque yo...
Old Jan 26, 2004 | 12:18 PM
Daemione's Avatar
Default Re: displacement calculator-- how much to bore H22 (MaxBoost)
Yours is the same formula (just more complicated).
Algebra is your friend.
aimmotorsports
Nov 9, 2006 02:24 PM
turbochargeb18c
Jan 7, 2006 05:28 PM
s-tech
May 4, 2005 11:14 AM
chandler
Apr 9, 2005 02:44 PM
kwik93si
Jul 12, 2003 01:32 PM
