is a T3/t04b good enough for 350-400 hp?
i have a t3/t04b 57 trim .63 a/r and was woundering if that turbo would be good enough for 350-400hp around 20-25psi??? if not i may need a new turbo... this will be going on a d series motor pistons, rods, and a fully built head to rev to 8k
ive seen a mildy built si make 370 to the wheels with that turbo on like 26 psi, but the turbo was at its limits, any more than that and its efficiency range is ****, itll just start to create heat and make less power, i wouldnt push the turbo passed 20-22 psi because of heat issues and taking into account that the turbo isnt too efficient passed that, the higer you go past the efficiency range your just gonna lose power and work the living **** out of the turbo.......
street_ride14
Jun 21, 2008 09:27 PM
