water temp gauge install help...
I have one from autozone and just install it you will need a tee fiting and you will need the extra parts that came with it use the smaller one that will fit the temp gauge sensor then fit a tee fiting that big and will need some extra parts to make the stock sensor bigger then will need a bar with screw side on both end to srew in the tee fiting in the block where the stock temp sensor it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorty91 »</TD></TR><TR><TD CLASS="quote">i bought a cheap water temp gauge from autozone, instead of taking out the temp sensor could i just wire the gauge to the existing temp sensor?</TD></TR></TABLE>
No, the sensors use different values and are not interchangeable.
TypeR15
Feb 24, 2004 12:29 PM
