Hard time removing Front Lower Control Arm??? Please Help!!!!
Old Jan 24, 2004 | 01:35 AM
poop32145432's Avatar
Default Hard time removing Front Lower Control Arm??? Please Help!!!!
I'm trying to install a CTR front Sway bar but in order to do so I must replace my OEM LCA's with the GSR LCA which is what I already have. Below is a picture of where I'm stuck at. The LCA won't come off the bottom of the strut.
I've banged on it with hammers.
pryed it with break bars.
sprayed WD40 on it.
chiseled at it.
stomped on it.
I did all of this while pushing up against the upper control arms to relieve pressure off the bolt. Am I doing something wrong? Please help. I've even put everything back on and started with that point first, still no luck, please pass on some guru advice to me. Thanks in advance.
Modified by mp7235 at 2:46 AM 1/24/2004
Modified by mp7235 at 2:47 AM 1/24/2004
Modified by mp7235 at 2:48 AM 1/24/2004
Modified by mp7235 at 12:27 PM 1/24/2004
Modified by mp7235 at 12:28 PM 1/24/2004
Old Jan 24, 2004 | 06:13 AM
92b16vx's Avatar
Try using the right tool, a ball joint puller will pop it out in a couple seconds.
Old Jan 24, 2004 | 08:45 AM
Hondaaccordvtec's Avatar
Default Re: (92b16vx)
if nothing else has worked, try using a pickle fork - just be careful not to trear the ball joint boot.
Old Jan 24, 2004 | 08:46 AM
B18C2_sedan's Avatar
Default Re: Hard time removing Front Lower Control Arm??? Please Help!!!! (mp7235)
beat harder. or use a fork
Vladglad
17
Apr 23, 2014 08:07 PM
Rand The Man
Jul 7, 2010 01:53 AM
si90rex
Welding / Fabrication
10
Mar 15, 2008 06:06 PM
superman3503
May 25, 2006 03:26 PM
agent marlon
Nov 11, 2002 04:41 PM
