why is there noise coming...
Old Jan 23, 2004 | 08:28 PM
distortedfuture's Avatar
Default why is there noise coming...
just wanted to know why there is noise coming from the back left and right side. i got h&r springs matched with kyb agx's at 1.75 drop in front and 1.5 in the rear. is it just because they are settling, or is this something that i should be worried about. anything would help.
Old Jan 23, 2004 | 08:43 PM
HATCHingMN's Avatar
Default Re: why is there noise coming... (distortedfuture)
go back and double or triple check your work, make sure all screws are all within torque spec
Old Jan 23, 2004 | 10:14 PM
pheen0m's Avatar
Is it a rattling sound? Check the upper mount bolts to see if they came loose.
Old Jan 23, 2004 | 11:31 PM
it's a little rattle when i hit a bump a certain way.
Old Jan 24, 2004 | 08:49 AM
Mugen Hamster's Avatar
I also have this problem with my H&R's and my Koni Yellows. It kinda sounds like there's a metal washer being shaken around in a soda can. But, everything is working fine and tightened up well.
Old Jan 24, 2004 | 09:12 AM
GTlvr82's Avatar
Default Re: why is there noise coming... (AntiRice Superstar)
I have Koni Yellows with Neuspeed Race Springs (don't evAR buy these ) and they rattle around also. I made sure everything was to spec....
Old Jan 24, 2004 | 10:45 AM
HondaCutter's Avatar
Default Re: why is there noise coming... (GTlvr82)
I had that problem with my Neuspeed Race's (don't ever buy these), but it turned out that the spring was sitting directly in the cup of the upper mount thing. When I corrected that it got rid of the rattle. Also, you guys didn't take out your spring insulator's did you? that would also cause a rattle, I think.
Old Jan 24, 2004 | 02:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AntiRice Superstar &raquo;</TD></TR><TR><TD CLASS="quote">I also have this problem with my H&R's and my Koni Yellows. It kinda sounds like there's a metal washer being shaken around in a soda can. But, everything is working fine and tightened up well.</TD></TR></TABLE>
yeah, that's pretty much how it sounds. not that a bolt is loose.
Old Jan 24, 2004 | 02:24 PM
endlesswinterco's Avatar
i have a loud clunking sound from my rear right. i hae sus. tech springs with tockico 5ways. i have checked everything, strut mounts, bolts, the lca, and eveyrhing, cant seem to pin point it. anyone?
Old Jan 25, 2004 | 12:32 AM
bump
Old Jan 25, 2004 | 02:14 PM
one last bump.
DC2man
Suspension & Brakes
Mar 28, 2007 11:11 AM
i97supratti
Suspension & Brakes
Aug 23, 2006 01:29 PM
eric8876
May 31, 2004 04:01 PM
TSAngry
Apr 29, 2004 09:42 PM
