Need help patching/fixing my CF lip
Old Jan 23, 2004 | 01:00 PM
Sassafrass's Avatar
Default Need help patching/fixing my CF lip
I just got my cf lip, and theres a bit of a crack/scuff. I'm very happy with it overall, and the crack is at the bottom almost impossible to see looking straight on. But I still know its there, I was just wandering if anyone knows how I can fix it or make it look better.
The crack is starting to lift of a chunk of clear coat, so its not clear its foggy white, so it does kinda stick out. What can I do? Wet sand and reclear it? Like I said its almost at the very bottom so its hard to see, so I just want to take the white out of it, so it doesnt stand out as much.
Old Jan 23, 2004 | 01:07 PM
redlinetuning's Avatar
Default Re: Need help patching/fixing my CF lip (Sassafrass)
return it...
Old Jan 23, 2004 | 01:09 PM
Sassafrass's Avatar
Default Re: Need help patching/fixing my CF lip (redlinetuning)
bought it used, I knew it had this problem.
Old Jan 23, 2004 | 01:28 PM
slammed_93_hatch's Avatar
well i don't think you cracked the lip. probably just the clear coat you could sand that down and then redo the clear coat. and you cant fix or patch carbon fiber and have it still look nice. its damn near impossible. and i highly doubt the CF is cracked probably jus the clear ocat
Old Jan 23, 2004 | 01:32 PM
sorry.. wasn't sure if you got it used or new.. in that case.. i've never tried repairing CF .. If I were you I'd keep it the way it is and not risk the chance of messing things up.
Old Jan 23, 2004 | 01:33 PM
wdskuk's Avatar
Clear coat it.
Old Jan 23, 2004 | 06:39 PM
Sassafrass's Avatar
Default Re: (wdskuk)
Ya no problems, I should have mentioned it was used, and I also should have mentioned I didnt crack the CF, your all right all I did was crack the clear coat.
Before I reclear it, do I sand it? with what type of sand paper? wet sand?
Inextricabledrvr
Paint and Body
Jun 27, 2008 06:49 PM
civicsracer
May 5, 2007 07:00 PM
Spectrum24x
Dec 9, 2005 05:46 AM
iwantfastcars
Nov 19, 2002 11:16 AM
