Front Shock Fork Question
Old Jan 23, 2004 | 11:27 AM
Rare BlueSI's Avatar
Default Front Shock Fork Question
My buddy KEN has a 91Si Hatch and he has a bent Front Shock Fork , along with this he has a ITR Swap which includes a five lug conversion and with the suspension he has ITR Shocks and Struts and also TEIN S-Tech Springs on his Suspension will He need to use only the ITR Front Fork for this to work or can he use a 99 SI Front Shock Fork??? What are his options!!!
ITR?
99SI?
Old Jan 23, 2004 | 03:23 PM
Black R's Avatar
25 Year Member
Default Re: Front Shock Fork Question (Rare BlueSI)
.....I would like to know this also!
Old Jan 23, 2004 | 03:32 PM
TypeR 599's Avatar
You mean the holes don't line up on the fork type of bend?
Denny and I fuxed up his front fork to where the holes don't line up. We got 2 long *** pipes. 1 pipe goes through the hole where the shock sits to hold the piece steady.Then we stick one side of the fork into another pipe, lift it and bent it back to normal. Everything lined up fine afterwards
Old Jan 23, 2004 | 03:50 PM
mstewar's Avatar
Default Re: Front Shock Fork Question (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">.....I would like to know this also! </TD></TR></TABLE>
lol.. i tried to ask something along these lines 2 weeks ago!
https://honda-tech.com/zerothread?id=733806
got no real answer, btw..
Old Jan 23, 2004 | 06:35 PM
HondaRcB's Avatar
Default Re: Front Shock Fork Question (mstewar)
The ITR and SI forks should be the same, but they're different from the original fork on his 91. When I put ITR shocks on my 90 Civic Wagon I had to get EG front shock forks because the shocks are larger in diameter and would not fit in the EF shcok forks. Hope this helps. Let me know if you have any questions.
Old Jan 25, 2004 | 06:15 PM
Black R's Avatar
25 Year Member
Default Re: Front Shock Fork Question (HondaRcB)
.....everything posted above is correct.
I examined and compared the stock ef/ si setup vs my itr setup.
To use itr specific springs and shocks, you will need the shocks/ springs + top hats and front forks. For the rear, you will need the shocks/ springs + top hats and rear lower control arms. EVERYTHING bolts right up. (With a LOT of elbow grease.....)
Wow, the EF still isn't as stiff as I'd like though.....
CaRb0y
May 11, 2009 03:00 PM
mrdeadman
Mar 20, 2006 03:56 PM
integra95gsr
Nov 7, 2005 12:03 PM
transitions
Jan 27, 2005 06:49 AM
keys
May 17, 2002 06:07 AM
