B-series Transmission stripped mainshaft
Old Jan 23, 2004 | 09:14 AM
GapxGuy's Avatar
Sushi Buffet Champion
Default B-series Transmission stripped mainshaft
I have a bad GSR tranny and a B16 tranny with a stripped main shaft. Can I take apart both trannies and switch the mainshafts? Are both mainshafts the same? I also want to use the GSR 5th gear in the B16, will that be a problem? Thanks.
Old Jan 23, 2004 | 06:48 PM
GapxGuy's Avatar
Default Re: B-series Transmission stripped mainshaft (GapxGuy)
Bump
Old Jan 24, 2004 | 03:26 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GapxGuy &raquo;</TD></TR><TR><TD CLASS="quote">I have a bad GSR tranny and a B16 tranny with a stripped main shaft. Can I take apart both trannies and switch the mainshafts? Are both mainshafts the same? I also want to use the GSR 5th gear in the B16, will that be a problem? Thanks.</TD></TR></TABLE>
you can switch mainshaft, but you'll need to carry over the 1/2 gears from the countershaft of the new mainshaft you'll be usisng(gsr). if you do this it will work, but it will make your car slower in second gear!
http://www.allmotorhonda.com/t...s.htm
Old Jan 24, 2004 | 10:00 AM
GapxGuy's Avatar
Default Re: B-series Transmission stripped mainshaft (smokey2.0)
It's the other way around, I'll be using the B16 tranny with the GSR mainshaft and 5th gear. Will that be a problem?
Old Jan 25, 2004 | 12:28 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GapxGuy &raquo;</TD></TR><TR><TD CLASS="quote">It's the other way around, I'll be using the B16 tranny with the GSR mainshaft and 5th gear. Will that be a problem?</TD></TR></TABLE>you'll have to use the countershaft 2nd gear from the gsr tranny, it wont match up with the si's countershaft 2nd!
Jintegragsr97
Sep 15, 2008 01:59 PM
ludedeg
Apr 13, 2004 07:00 PM
GapxGuy
Jan 24, 2004 10:05 AM
GapxGuy
Jan 24, 2004 10:04 AM
