Skunk2 coilovers
Old Jan 22, 2004 | 10:01 PM
mattjcali22's Avatar
Default help!!! Skunk2 coilovers
When you are just getting the threaded sleeve what do you have to do to get them on a strut? Is there any cutting and welding involved or can you slide them on?
Old Jan 22, 2004 | 10:24 PM
Redline130's Avatar
Default Re: help!!! Skunk2 coilovers (mattjcali22)
You have to use rubber O-rings to "shim" in between the threaded sleeve and the strut body. The sleeve is wider in diameter than the strut, so you need those O-rings to keep the sleeves straight. But other than that, you just slide the sleeve over the strut.
Old Jan 22, 2004 | 10:44 PM
Default Re: help!!! Skunk2 coilovers (Redline130)
where would i get the o-rings
Old Jan 22, 2004 | 11:22 PM
Redline130's Avatar
If they didn't send them with the sleeves, I would call them to see if you can get some. When you buy the set, they send a bunch of different sized ones to work with a wide range of struts. If not, you could probably find some at a Home Depot or hardware store. Only problem then, would be finding the right size.
Old Jan 22, 2004 | 11:31 PM
thanks for the help.
quick_ls
Suspension & Brakes
Oct 26, 2009 07:55 PM
Throwback23
13
Apr 15, 2009 07:47 PM
lsjon
Mar 13, 2007 11:35 AM
Nocturnal
Nov 23, 2004 07:57 PM
1JDMDOMINICAN
Nov 15, 2004 07:55 AM
