CEL Code 21 (VTEC Spool Valve) quick question REWARD INSIDE
Old Jan 22, 2004 | 09:43 PM
G U E C O's Avatar
Default CEL Code 21 (VTEC Spool Valve) quick question REWARD INSIDE
hey i just installed my chipped p28 ecu and im pulling a CEL code 21 which is VTEC Spool Valve. my vtec is not wired yet and i am goign to get it done tommorrow (no vtec wires are wired yet). Is this the reason why i am pulling this code? Am i still safe to use my p28 ecu with this CEL?
thanks in advance
your reward is a for helping
Old Jan 22, 2004 | 09:44 PM
GTlvr82's Avatar
Default Re: CEL Code 21 (VTEC Spool Valve) quick question REWARD INSIDE (stock93cx)
Yes that should be the only reason you are pulling a code....if your wires aren't hooked up its gonna throw a code....
Old Jan 22, 2004 | 09:49 PM
G U E C O's Avatar
Default Re: CEL Code 21 (GTlvr82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 &raquo;</TD></TR><TR><TD CLASS="quote">Yes that should be the only reason you are pulling a code....if your wires aren't hooked up its gonna throw a code.... </TD></TR></TABLE>
i did a search and there was only ONE person that said thats why code 21 is poping up, but i need someone else to verify it.
thank you. here is your . its still safe to drive right?
Old Jan 22, 2004 | 09:51 PM
GTlvr82's Avatar
Default Re: CEL Code 21 (stock93cx)
Yeah its still safe to drive...just don't beat the **** out of it. Connect the wires and notice the difference.....VTEC will own you.....sorta. SOHC motors don't have the same POWA as DOHC...
EDIT: I am assssume you have a DOHC.....n/m bout the SOHC comment.
Old Jan 22, 2004 | 10:04 PM
G U E C O's Avatar
ya its for a DOHC, damn i just took it for a test drive damn its alot better than running a cx ecu (still pulls and im jsut shifting at 6k). My friend's been running his 92 SOHC CX ecu for about 2 months.
Old Jan 23, 2004 | 12:10 AM
Maintenance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock93cx &raquo;</TD></TR><TR><TD CLASS="quote">hey i just installed my chipped p28 ecu and im pulling a CEL code 21 which is VTEC Spool Valve. my vtec is not wired yet and i am goign to get it done tommorrow (no vtec wires are wired yet). Is this the reason why i am pulling this code? Am i still safe to use my p28 ecu with this CEL?
thanks in advance
your reward is a for helping </TD></TR></TABLE>
Yeah that's the reason your throwing the cel 21. yeah you'll be fine. Once you hook up the the vtec wire at a4 you'll be set
PaChiLa Leader
Nov 11, 2011 06:13 PM
toxicsynergy
Jul 29, 2008 05:18 PM
aZnjCC
Oct 16, 2005 03:18 PM
LudeJdm
17
Jun 11, 2005 09:34 AM
hondaadnoh
Jan 6, 2004 02:44 AM
