Hondata
Old Jan 22, 2004 | 12:46 PM
PeterSi's Avatar
Default Hondata
I want to put a 14b (1gen eclipse turbo) in my 94 civic si. I will need a hondata! Or do i just need an AFC. Which one will i need and were can i get it? Also can i controll it from my PDA?
Modified by PeterSi at 10:01 PM 1/22/2004
Old Jan 22, 2004 | 12:55 PM
JDMlyfestyle's Avatar
i dont think hondata will be capable for a eclipse motor. Just do a GSR swap and turbo it and woop the **** out of some GST's and GSX's
Old Jan 22, 2004 | 01:05 PM
b18bEG's Avatar
you wanna use the whole motor? or just the turbo?
Old Jan 22, 2004 | 01:22 PM
boosted2point2ek's Avatar
Default Re: (b18bEG)
you are crazy for thinking that....if you figure out how to do that let me know...i need a viper motor in my hatch????NOT
ignorance is bliss
Old Jan 22, 2004 | 02:30 PM
LudeHatchH22a's Avatar
you guys are flaming him and your all as dumb as stumps too!
he said a 14b turbo (which is a TURBO, not a M-O-T-O-R)
back on topic
I PERSONALLY think that you should save your money and get a 16g or a 20g turbo if you want to do it that way. I mean there are plenty of kits out there for your motor to be turboed.
But i myself would think a 16G or a 20G would be real good for a 1.6 motor. The 14b is a stock turbo, its power rang is from spool, till about 4500-5000 rpms when the boost lets off , not very good for a honda. A 16 or 20g will pull really well the whole way through, and not loose any boost at higher rpms, and still spool faster then a t3/t4. the t3/t4 is over rated in my opinion, but thats just me,
TO DO THIS:
you would need the turbo of course, go to machv.com, they have the HOOK UP on mitsu turbos, my suggestion would be to go with the 1st one on the page, (bousher 16g) because it has a internal wastegate which makes it easyier to hook up. ALSO, you need a custom manifold, and downpipe. All this will be custom, so your going to end up spending close to what a turbo kit will cost, but i think it would be more effective for your motor.
PM me if you have any questions, i know you'll be able to use the piping and possibly the intercooler(s) on your car
Old Jan 22, 2004 | 02:36 PM
BTW i forgot to asnwer your question. you will need a missing link adapter for your MAP sensor to prevent a CEL, then for the ECU you DEFINATLY want a hondata, or AEM EMS(being 1000$)
on a side note, i know newbs ask stupid questions, but maybe if you guys werent so busy flaming at every chanvce you get, and acctually offer son info for him, they wouldnt be so stupid!! i mean the posters on this thread didnt really flame, just obviously had a problem reading english (no help to the newb)
But im speaking more about the other posts ive been reading
oh yea
and its VTEC!!! LOL Variable valve Timing Electronicaly Controlled.
FOR THE WAY IT WORKS...go to workstuffworks.com and search for vtec, youll find most of what you want on that.
but yes, its about the cam lobes
Old Jan 22, 2004 | 03:12 PM
DaX's Avatar
DaX
Loved
Community Favorite
If you do Hondata, there is no need for a missing link, and if you're running less than around 11psi, you can use the stock Honda map sensor.
Old Jan 22, 2004 | 04:09 PM
Ricey McRicerton's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">If you do Hondata, there is no need for a missing link, and if you're running less than around 11psi, you can use the stock Honda map sensor.</TD></TR></TABLE>
And for under 10 psi I would say go with the AFC. Much less expensive than Hondata and is capable of handling low boost applications.
blackcruzan's Avatar
Default Re: (LudeHatchH22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeHatchH22a &raquo;</TD></TR><TR><TD CLASS="quote">you guys are flaming him and your all as dumb as stumps too!
i'm glad somebody pointed that out.
Old Jan 22, 2004 | 04:21 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
And for under 10 psi I would say go with the AFC. Much less expensive than Hondata and is capable of handling low boost applications.</TD></TR></TABLE>
Agreed. Unless you plan on boosting larger numbers in the future. Then I'd go ahead and spend the money on Hondata or some other expandable platform.
mattbnt0412
Aug 23, 2007 06:40 PM
redcivic44
Feb 6, 2006 05:33 PM
FBPninetynineEM1
Dec 25, 2004 03:51 PM
JrCRXHF
Oct 20, 2003 06:27 PM
JUN JDM
Apr 30, 2003 08:33 PM
