charging capacitor
Personally, I'd make sure it's discharged, then charge it according to the owner's manual...better to be safe then sorry...you don't want huge sparks!!
I would charge it as described in the owners manual. I would not worry about discharging it first. When a cap is charged it is less of a load. Whithout getting to technical when fully charge it draws 0 current. So if it is partially charged it will just require less time to charge.
if you want to discharge the cap, then get a small car light and put the end leads on the + and _ of the cap until the light goes completely out.. once a cap is discharged you can recharge it slowly by grounding the negative side. and use a resistor inline with the positve. on the cap..
usualy once a cap is charged you dont have to recharge it
