O2 bypass???
Old Jan 22, 2004 | 06:25 AM
Eresuncabron's Avatar
Default O2 bypass???
what is it.
this kid i kno got some type of chip for his ecu and he said it wouldn't work unless
he got an O2 bypass. to pass the sensor.
what do these do and is it ok to bypass the sensor?
just wonderin cuz i'm gettin a Code one on my rex(o2 sensor)
and i don't wanna get a new one cuz i'm swappin the engine in june
Old Jan 22, 2004 | 12:47 PM
R-Toyz.com's Avatar
Default Re: O2 bypass??? (Eresuncabron)
Probably the chip is set to run in open loop only....meaning that the ECU doesnt have to read signals from the o2 sensor to compute for idle and a/f values. This is why the O2 sensor is bypassed.
Used o2 sensors cost like $30. If you're getting a code 1, check for a short in the wiring or something. That may solve it without having to replace the whole thing.
Old Jan 22, 2004 | 03:00 PM
Default Re: O2 bypass??? (rtzcom)
I'm pretty sure it's not wiring cuz the CEL only comes on after the car is heated up and i lean on it.
Old Jan 23, 2004 | 04:29 AM
R-Toyz.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eresuncabron &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure it's not wiring cuz the CEL only comes on after the car is heated up and i lean on it.</TD></TR></TABLE>
Same thing happened to me. CEL comes on after a while of driving. A wire in my O2 hit the headers so the insulation melted. That caused a short and threw the CELs.
Old Jan 24, 2004 | 06:18 AM
I'll Hafta Cheack that out. Thanx
Nooget
13
Aug 14, 2010 08:12 PM
sde780
Dec 15, 2009 04:54 PM
kapoosh valve
23
Jul 1, 2005 09:02 PM
terminaloverlowd
10
Jul 27, 2004 03:12 PM
anothersickhatch
May 15, 2004 10:22 PM
