>>>D16Z6 Swap HELP!!!!!<<<
Old Jan 21, 2004 | 08:31 PM
mamaboy's Avatar
Default >>>D16Z6 Swap HELP!!!!!<<<
I've been reading and reading and reading almost all the topics using of course https://honda-tech.com/zerosearch about the d16z6 swap into my 88 D15B1 Civic Hatch. I'm trying to gather all the information and hoping that somebody can acknowledge or correct my list of things to do....
1. D16Z6 Engine
2. Can I reuse the S20 Transmission?
3. D15B1 Driver side Motor mount
4. DPFI to MPFI conversion
5. P28 ECU
6. OBD-0 to OBD-1 Jumpers (Contact blownn90hatch)
7. Install and I'm Done!
Transmission is my biggest concern. The MPFI conversion seems abit tricky. Any HELP is greatly welcomed.
Old Jan 22, 2004 | 04:08 AM
VTECVillain's Avatar
Default Re: >>>D16Z6 Swap HELP!!!!!<<< (mamaboy)
The S20 is the hydro tranny from the Z6 correct? You can't use it unless you fabricate your own upper tranny mount and rear tranny bracket. Then you would need the HASport hydro to cable mechanism or install the hydro system.
Just get an 88-91 Civic/CRX Si cable tranny or a DX one at least. The gearing of the DX and Si are the same except the Si has a slightly better final drive. Other than that it looks like you're off to a good start with your research.
Old Jan 22, 2004 | 05:22 AM
mamaboy's Avatar
Default Re: >>>D16Z6 Swap HELP!!!!!<<< (VTECVillain)
i guess i'm calling hasport! anything else? injectors? distributor?
hmonkey86
Nov 28, 2011 09:19 AM
bumm03
Feb 28, 2010 08:24 AM
TeamRedline89Hatch
13
Nov 18, 2005 12:18 AM
xclusiv_civic
10
Jun 19, 2004 07:58 PM
fkncivic
Nov 14, 2002 06:22 AM
