anyone know the specs for the jdm b18b?
i want to know the complete specs if anyone knows or any site that tells? i reallie need tot the compression, hp, torque,redline?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob »</TD></TR><TR><TD CLASS="quote">im pretty sure they are the same as the usdm ones.</TD></TR></TABLE>
i thought that jdm motors were supposed to have 10 more hp due to them not carring about emissions?
for instance:
- usdm b16a is 160 while jdm b16a is 170
- usdm b18c is 170 while jdm b18c is 180
so..i was thinking
- usdm b18b is 142 so that would make jdm b18b 152?
not sure about torque but i think that only changes at the most by 4 or 5..
I am purchasing a jdm b18b so this is what i was thinking..
for instance:
so..i was thinking
145Hp 127Trq 9.4 Compression (JDM)
142Hp 127Trq 9.2 Compression (USDM)
taken from http://www.hmotorsonline.com
Here I pulled some info for you.....
93-94 JDM Integra ESi has a b18b motor and here are the specs
Engine - 1.8L, 4 cylinder, DOHC
Valavetrain - 16 valve, 4 valves per cylinder, dual overhead camshafts, belt driven
Power - 145 PS (142 HP) @ 6300 RPM
Torque - 17.4 kg-m (126 lbs-ft) @ 5200 RPM
Compression - 9.2:1
PowerTrain - Transverse front engine, front wheel drive (FF)
I personally don't know specifics...but I thought this would help
Compression - 9.2:1
Like I said I dunno personally, but that is for a 93-94 Integra ESi, which is the only JDM integra (I could find) with a b18b
now there are other models with b18c, b18c (specR) and then they have other engine codes like ZC
weavertime1
Feb 14, 2012 08:59 AM
stripes777
Mar 8, 2004 09:37 PM
