Can someone help me with automatic tranny flush/refill
whats up. i dont browse thru this forum much since i be in the EG forum but my question is How would i go about changing a 2000 accord v6 auto transmission fluid. I tried searching but couldnt find what i was looking for. Is it anything similiar to 4 cyclinder motors? Im dont know much about this v6 motor so if anyone could help or give me a link, it would be much appreciated. tia
If i remeber correctly, there is a 17mm plug on top of the trans, should be visible, drain it through the 3/8" drive plug on bottom, then fill approx 2 quarts through the 17mm plug on top
it is the same as 4 cyl hondas but the tranny is on the other side.... the tranny uses 2.75 quarts of fluid use only honda atf because that tranny is the biggest piece of **** honda has ever built
Poopie
Nov 24, 2004 06:47 AM
