Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
CRV rims questions
Old Jan 21, 2004 | 03:46 PM
CS-CRV's Avatar
Default CRV rims questions
OK I am bout to buy a 2003 or 2004 Honda CR V. I was wondering what is the biggest rims I could put on it with out rubbing? Please tell me whats the big size and the tire I would have to put on it with out rubbing.. I would like to put 20"s but I dont know if thats possible is it? How many lugs is the 03-04 CRV? What pattern is it? Let me know
THANKS
Old Jan 22, 2004 | 10:49 AM
MIDNIGHT's Avatar
Default Re: CRV rims questions (CS-CRV)
18s with 225/45-18 tires
you can put 19s on it but unsure about tires
Old Jan 22, 2004 | 12:21 PM
CS-CRV's Avatar
Default Re: CRV rims questions (MIDNIGHT)
So I cant put 20"s?
Old Jan 22, 2004 | 09:51 PM
MEANB18's Avatar
26's but they have to be spinners. If they don't spin, then 22's are the biggest you can go.
I would think you could fit 20's though?
Old Jan 24, 2004 | 09:57 AM
DooD's Avatar
Default Re: CRV rims questions (MEANB18)
i've seen 20's on...but it's a lot of rubbing and damn ugly IMO.
Biggest i would go would be 18's....MAX 19's.
But i went with 17's. A good balance between big and TOO big.
Old Jan 24, 2004 | 08:34 PM
JDMITR22's Avatar
I've seen 20's on a crv. you might get some rubbing in hard turns but other than that its good.
Old Jan 24, 2004 | 10:15 PM
roydogg's Avatar
Default Re: (JDMITR22)
20's will fit but you'll have to upgrade your suspension and get the right offset. 245/35-20 tires little rubbing but really slow unless you have boost. I had 20's and hated it get 19's,suspension, and a supercharger .
Old Jan 29, 2004 | 07:12 AM
flyers8899's Avatar
I Like 5 Lug Hubcaps
Default Re: (roydogg)
go with 18's, i seen pics with 20s on them and it just doesn't look right on CRVs
Old Feb 1, 2004 | 08:24 AM
99SlammedCivic's Avatar
Snipper Snapper
hey can the Accord 5 lug rims fit on a 2001 CRV?
Old Feb 1, 2004 | 09:33 AM
roydogg's Avatar
Default Re: (99SlammedCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99SlammedCivic &raquo;</TD></TR><TR><TD CLASS="quote">hey can the Accord 5 lug rims fit on a 2001 CRV?</TD></TR></TABLE>
Sure can, thats what I got on my CR-V .
Old Feb 3, 2004 | 05:19 PM
luciferi's Avatar
20" will fit but it will require some trimming of the rear plastic depending on the tire width, offset, and camber. If you are not planning on lowering, you should not have an problems. Nitto now makes a 225/35-20.
Old Apr 5, 2004 | 08:44 AM
Suzukablue's Avatar
Would a set of 18" Racing Hart S7 that came from an RSX fit my CRV. Tires are 225/40/18.
Old Apr 5, 2004 | 10:19 AM
roydogg's Avatar
Default Re: CRV rims questions (eg_ko_2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_ko_2 &raquo;</TD></TR><TR><TD CLASS="quote">Would a set of 18" Racing Hart S7 that came from an RSX fit my CRV. Tires are 225/40/18.</TD></TR></TABLE>
Yes it will, might need to lower the crv a little though
Old Apr 5, 2004 | 10:41 AM
Suzukablue's Avatar
Default Re: CRV rims questions (roydogg)
thanks roydogg. would the 40 series be just the right size or is there a recommended tire size?
bdmlilburn
Jun 13, 2011 08:33 AM
mike_sir
38
Aug 11, 2009 11:01 AM
specscow
Mar 27, 2006 11:32 PM
h22accordturbo
Nov 5, 2002 02:27 PM
hobo79
Oct 9, 2001 12:08 PM
