car wont start, should i get a new battery?
Old Jan 21, 2004 | 08:37 AM
AirWaveGT's Avatar
Default car wont start, should i get a new battery?
This has happened to me a few times now in the past week or so. if i get a jump or pop start the car it will start up fine for a few days but if i dont start it for like 16 hours or so it wont start. i also have two amps in my car making about 1000-1100 watts but even when i keep them turned off the same thing happens. Should i just get a new battery now and what kind should i get? I also plan on getting a higher output alternator but it wouldnt be for a month or more and then i would have to find the time to install it.
Old Jan 21, 2004 | 08:41 AM
AirWaveGT's Avatar
Default Re: car wont start, should i get a new battery? (AirWaveGT)
by the way i would need to get the battery today so i will be able to drive to school tomorrow. so ordering one online isnt an option. i was looking at optima yellow and red top. are these any good, do they even fit and which one would work better for me
Old Jan 21, 2004 | 09:21 AM
AirWaveGT's Avatar
ok, well im going to go to advanced auto parts now and see if i can get an optima yellow top that i can fit in my car. if not ill just get whatever else they have
Old Jan 21, 2004 | 09:33 AM
JimBlake's Avatar
Make sure your alternator is charging. You need to see 13v or 13.5v at the battery posts while the car is running. Even with stuff like lights & fans running. If not, you'll just drain your new battery, too.
Old Jan 21, 2004 | 11:51 AM
AirWaveGT's Avatar
Default Re: car wont start, should i get a new battery? (JimBlake)
yeah, i need to check that and make sure. im gonna get a new alternator as soon as i can though so i should be fine
Old Jan 22, 2004 | 07:08 AM
Creep's Avatar
is your batt light on, I imagine your charging system is ok if not.
Your problem is probably just an old bat that wont hold charge.
Old Jan 22, 2004 | 08:04 AM
AirWaveGT's Avatar
Default Re: car wont start, should i get a new battery? (Creep)
the battery light never cam on. since i switched them out yesterday it has been running fine with no problem so far. i will still most likely get a new alternator that can handle my amps better.
Old Jan 22, 2004 | 02:15 PM
TRH's Avatar
TRH
Better get a <U>BIGGER</U> alternator
Old Jan 22, 2004 | 02:36 PM
AirWaveGT's Avatar
Default Re: car wont start, should i get a new battery? (TRH)
i was planning on getting a higher output alternator
sixfourkiller
Jun 17, 2009 10:05 AM
hackykid
Aug 8, 2007 11:16 PM
snzh22
Nov 13, 2006 01:46 PM
selasornayr
Jun 28, 2005 02:53 PM
