Idle Air Control Valve throwing CEL in Euro R ( H22a ) Swap. HELP!
Old Jan 20, 2004 | 07:04 PM
AkEuro_R's Avatar
Default Idle Air Control Valve throwing CEL in Euro R ( H22a ) Swap. HELP!
I need to know if anyone has done this swap in an eg hatchback and how they made it work. The car idles up and down but stays running. I need to know what it will take to wire it or tune it so it goes away. Please help
Old Jan 21, 2004 | 01:39 PM
tomtom211's Avatar
Default Re: Idle Air Control Valve throwing CEL in Euro R ( H22a ) Swap. HELP! (AkEuro_R)
you have to make an adapter plate and use a 2 wire IAC valve(like that on a OBDI accord) instead of the 3 wire IAC valve that comes ont the euro R motor.
Not sure what ECU your running, but chances are it's not gonna control the 3 wire IAC unless it's OBDII.
Old Jan 21, 2004 | 01:58 PM
junbb1's Avatar
Default Re: Idle Air Control Valve throwing CEL in Euro R (tomtom211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomtom211 &raquo;</TD></TR><TR><TD CLASS="quote">you have to make an adapter plate and use a 2 wire IAC valve(like that on a OBDI accord) instead of the 3 wire IAC valve that comes ont the euro R motor.
Not sure what ECU your running, but chances are it's not gonna control the 3 wire IAC unless it's OBDII. </TD></TR></TABLE>
what he said. also remember that you also have to plug the fuel air injection ports above the runners or it will create a vacum leak. and if you are using a stock T/B then you need to make sure you modify it for sealing. see the post i made in this forum just yesterday for some more tips.
Old Jan 21, 2004 | 01:59 PM
4bidden's Avatar
Default Re: Idle Air Control Valve throwing CEL in Euro R (junbb1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junbb1 &raquo;</TD></TR><TR><TD CLASS="quote">
what he said. also remember that you also have to plug the fuel air injection ports above the runners or it will create a vacum leak. and if you are using a stock T/B then you need to make sure you modify it for sealing. see the post i made in this forum just yesterday for some more tips.</TD></TR></TABLE>
Sounds to me like he swapped a complete Euro-R, not just the manifold....so he wouldnt have to worry about the things you mentioned.
Old Jan 21, 2004 | 02:07 PM
junbb1's Avatar
Default Re: Idle Air Control Valve throwing CEL in Euro R (4bidden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds to me like he swapped a complete Euro-R, not just the manifold....so he wouldnt have to worry about the things you mentioned.</TD></TR></TABLE>
yep i think you are correct. sorry bud good luck
Old Jan 21, 2004 | 05:31 PM
AkEuro_R's Avatar
Yes sir its the entire swap. I really appreciate the help. I was at a lost and wanted to break into tears I assume I can use a generic h22 iacv obd1 ? I am using an import builders p28 just so you know
Old Jan 21, 2004 | 08:57 PM
tuan...'s Avatar
hey i got an iacv sittin around, used for like 1 min as an attempt to fix an idle but didnt solve the problem. hit me up with an offer
Old Jan 21, 2004 | 10:35 PM
AkEuro_R's Avatar
Default Re: (h22a4_dc2)
what are u looking to get
xKING239x
Mar 29, 2013 10:03 AM
ramzan_anwar
Nov 28, 2012 07:36 PM
hatchback_al
Aug 6, 2003 01:51 PM
