STUMPED: The Beater Is Actin Up, any suggestions???
Old Jan 20, 2004 | 06:17 PM
FULL-RACE EP3's Avatar
Default STUMPED: The Beater Is Actin Up, any suggestions???
Well lately my beaters' been havin a bit of difficulty starting. Its a 89dx with 120,xxx miles that I just picked up a couple months ago. When I got it I did the basic tune up stuff, cap, rotor, plugs, etc...
Anyways, lately when I go to start it, the car will start and then just die. So i'll try to give it a little rev when it starts and it revs up once after if fires up and then it'll just die. But then sometimes it will start after a few try's and an occasional rev. This has been randomly happening and was just wondering if any of you guys had any ideas???
BTW--I've actually tried to pull the ecu fuse after several attempts and she'll fire right up afterwards like nothing ever happend, which leaves me scratchin my head. No CEL, or anything either.
Old Jan 20, 2004 | 06:54 PM
IwantaGlock18's Avatar
Default Re: STUMPED: The Beater Is Actin Up, any suggestions??? (Pooptooth)
maybe your injectors are going out. But that still wouldn't explain the ecu fuse.
Old Jan 20, 2004 | 07:02 PM
ITSTOCK's Avatar
Default Re: STUMPED: The Beater Is Actin Up, any suggestions??? (dsman)
test the ignitor in the dist. i had a similiar problem and it was the ignitor.
Old Jan 20, 2004 | 09:32 PM
Kasper.'s Avatar
Default Re: STUMPED: The Beater Is Actin Up, any suggestions??? (ITSTOCK)
Id check for high resistance at the ignition switch.
Old Jan 21, 2004 | 05:49 AM
thanks for suggestions, i will test them out today. Keep em coming, just incase...
Old Jan 26, 2004 | 09:27 AM
quickda6's Avatar
LOL its you ignitor bitch
Old Jan 26, 2004 | 09:52 AM
Buzzbomb's Avatar
Something very similar happens on my 89 HF with 180K. It takes more turns than normal to start and when it does, it's barely running and then dies. I let it sit for a couple of seconds and then start it again and it's fine. This only happens once every 4 months or so.
I think it comes down to fuel delivery. Vaperlock? Fuel pump not building enough pressure? It has never stranded me so I don't worry about it.
Old Jan 26, 2004 | 10:49 AM
vitrox's Avatar
its your main relay probably, here is the fix, its pretty easy and costs nothing, so its worth a try. http://www.crxsi.com/resources...relay/
Old Jan 26, 2004 | 11:12 AM
Default Re: STUMPED: The Beater Is Actin Up, any suggestions??? (Buzzbomb)
thanks guys, yeah it doenst ever not start so i'm not too worried about it, but i just wanted to address it before it got worse. Oh, and Josh---E.A.D.
TheWhopper
May 8, 2019 05:59 AM
integrals21
Jan 8, 2010 04:45 PM
poundedhatchcrap
Aug 25, 2005 02:29 PM
2ndGenGsr
May 18, 2003 01:58 AM
hahahahhah
18
Feb 13, 2003 10:59 PM
