High-Altitude Street Tuning Q'S?
Old Jan 20, 2004 | 05:50 PM
Street_Kings's Avatar
Default High-Altitude Street Tuning Q'S?
i'm in denver, colorado, where my current altitude is 5280' (a mile). Just curious as since the air is not as dense as all the sea level guys, do i still tune the same? shoot for a 12:1 AFR and pull timing ~ .75 Deg/PSI? Anybody have any experience with this?
Old Jan 20, 2004 | 06:15 PM
Joseph Davis's Avatar
Default Re: High-Altitude Street Tuning Q'S? (Street_Kings)
I'm half your elevation and I follow the usual tuning recommendations. Keep an eye open if you make drastic altitude changes, some engine management setups will be less friendly to such changes, or require tuning to cope with altitude changes as well.
I notice I don't push as much boost at mile high altitudes (when on the Parkway) due to the lower atm pressure, but I don't get more than a psi increase at sea level from my usual 2700 ft.
Old Jan 20, 2004 | 06:30 PM
951's Avatar
951
Default Re: High-Altitude Street Tuning Q'S? (J. Davis)
stock ECU will compensate for you.
Old Jan 20, 2004 | 10:11 PM
Default Re: High-Altitude Street Tuning Q'S? (951)
even if i'm running UBerdata? i thought uberdata overrode most factory ECU compensations?
masterEF
Nov 10, 2009 05:56 PM
DriveSlowHomie
Sep 23, 2005 05:52 AM
hatchedzex
Dec 19, 2004 02:32 PM
Propulsion
May 13, 2003 12:59 AM
dwilson
Jan 28, 2003 03:32 PM
