Apexi AVCR (posted in the "forced induction" section w/ no reply)
Old Jan 20, 2004 | 04:38 PM
killa_lude's Avatar
Default Apexi AVCR (posted in the "forced induction" section w/ no reply)
i noticed that the Apexi AVCR is a "closed loop" boost controler..can you run an open loop setup w/ this bc? if not what would happen?
Old Jan 20, 2004 | 07:16 PM
boostlee's Avatar
Default Re: Apexi AVCR (killa_lude)
might not work right. can mess up engine if not wired correctly
i was looking at the avcr book and i just saw the scramble switch hook up, i might try it. its a momentary switch to activate a higher boost set point only when pressed
http://www.cardomain.com/id/boostlee
Old Jan 21, 2004 | 08:35 AM
killa_lude's Avatar
Default Re: Apexi AVCR (boostlee)
hmm yeah...i'm not sure if i want to run that bc then....what are some "open loop" bc's out there? yeah i like your setup, i've checked out your cardomain page many times....
cardomain.com/id/killa_lude
Chiovnidca
Oct 27, 2007 04:30 PM
OMG B16
Jun 2, 2006 09:27 PM
killa_lude
Jan 20, 2004 12:47 PM
Drkaccrd
Mar 2, 2003 07:48 AM
