Third alternator...
Old Jan 20, 2004 | 03:47 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Third alternator...
second distributor, third ignitor all in three months...
that is all...
/rant
stan
Old Jan 20, 2004 | 03:56 PM
Vero's Avatar
take out the really big boom booms.
that or get a beefier altenator and capacitor.
Old Jan 20, 2004 | 04:58 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (Vero)
Ha IM on my 3rd alt as well second pair of axles..... Life sucks when crap breaks, but sure is good when everything is running well....
Blaze
Old Jan 20, 2004 | 05:14 PM
Default Re: (Vero)
no stereo at all, the car is on it's way to being a track only car.
after checking it could be something else after all.
Stan
Old Jan 20, 2004 | 05:20 PM
Tyson's Avatar
Default Re: (Stan D)
do you have a engine kill switch? my longacre battery/alt cutoff switch was killing my alternators. went thru 3 or 4 in 2 years.
Old Jan 20, 2004 | 05:26 PM
Default Re: (Tyson)
i feel that i should explain this more in detail, my first post was venting.
i don't believe that the alternator is dead after all.
here is the recap.
after installing MSD cap and blaster coil, the car obtained a miss at high RPMs. It is also extremely hard to start the car, i drain the batter each time almost completely, which led me to believe at first that it was not charging (happened twice before, took a month to diagnose). the miss and hard start also mean that there is a weak voltage, either in the entire system, or most likely in the ignition system.
so, voltage while charging is 13v, better that usual, runs great until 4.5-5k where it begins to miss. and very hard starts, almost impossible.
i should also mention that i installed the MSD **** only after my coil and igniter failed. i decided to get something better along with a new igniter.
stan
Old Jan 20, 2004 | 05:27 PM
Blaze45's Avatar
Brrraaaap!
No radio? Check the cig lighter fuse that always goes out on my car. gayness cause theres a short somewhere...
Blaze
DatOneGuy
Jan 15, 2015 04:33 PM
B bOy CrAyOn
Aug 8, 2007 11:25 PM
93SIRII
14
Aug 7, 2007 05:03 AM
The Brown Kid
Dec 18, 2002 04:19 PM
