removing catalyic converter
Old Jan 20, 2004 | 02:00 PM
krnboixshawn's Avatar
Default removing catalyic converter
im planning on removing the catalyic converter and was told that the check engine light will come on. someone told me that when the check engine light comes on the car goes into a safety mode or some sort and will effect the performance of my car. is this true? should i keep it on or will it be ok to remove it. thanx for your help
Old Jan 20, 2004 | 02:03 PM
PrecisionH23a's Avatar
Default Re: removing catalyic converter (krnboixshawn)
What year is the car/motor?
Old Jan 20, 2004 | 06:24 PM
Default Re: removing catalyic converter (PrecisionH23a)
2001 prelude sh
Old Jan 20, 2004 | 06:29 PM
@ries's Avatar
Yes the check-engine light will most likely come on although they sell O2 simulators to by-pass this problem. I've done a few tests on the dyno and found out that at wide-open throttle (check-engine light on for the secondary O2) the performance was the same.
Old Jan 20, 2004 | 09:34 PM
speedracer9k's Avatar
when you remove the cat do you mean run straight header or are you going to put a test pipe in? Just wondering b/c i'm trying to figure out the reason to WHY you would want to remove the cat.
Old Jan 20, 2004 | 09:39 PM
redmethods's Avatar
PRO FOR MANCE
Old Jan 20, 2004 | 09:50 PM
TruNinja619's Avatar
Default Re: (speedracer9k)
well... if ur gonna take the cat. converter off.. ur still gonna have the rest of the piping left.... so ur jus gonna have to weld the piping to the headers....
Old Jan 21, 2004 | 12:04 AM
Wiseguy619's Avatar
Default Re: (TruNinja619)
hi-flow cat .
Old Jan 21, 2004 | 12:14 AM
@ries's Avatar
Default Re: (ProjectPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectPenny &raquo;</TD></TR><TR><TD CLASS="quote">hi-flow cat .</TD></TR></TABLE> straight-pipe (shhh)
Old Jan 21, 2004 | 09:15 AM
killa_lude's Avatar
Default Re: (emoBB1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emoBB1 &raquo;</TD></TR><TR><TD CLASS="quote"> straight-pipe (shhh) </TD></TR></TABLE>
the only way to drive, cheaper too!
Old Jan 21, 2004 | 11:17 AM
SKDRCR's Avatar
Default Re: (killa_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude &raquo;</TD></TR><TR><TD CLASS="quote">
the only way to drive, cheaper too! </TD></TR></TABLE>
or just get rid of the cat and get a resonator
to quiet things down a little
Old Jan 21, 2004 | 05:45 PM
iam7head's Avatar
Default Re: (SKDRCR)
can i recommend random cat?
they are smog legal, as far as i know.
dont get caught without a working cat in socal
Old Jan 22, 2004 | 02:52 AM
Revi's Avatar
Default Re: (iam7head)
can anyone confirm the engine going into limp mode after the check engine light comes on? How do you reset it? Mine came on about 4 months ago but it went away quickly, it ended up being ATTS related. Will this still put it in "limp mode" if it even does that?
Old Jan 22, 2004 | 05:45 AM
u got that right.... california got the strictest car-related laws in country....
Old Jan 22, 2004 | 09:45 AM
VTECRaZeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">can i recommend random cat?
dont get caught without a working cat in socal</TD></TR></TABLE>
Don't get caught with a straight pipe in California period. You'll get a little more then a ticket.....Should I say don't drop the soap...
Old Jan 22, 2004 | 11:23 AM
dblair's Avatar
Default Re: (VTECRaZeR)
It's even illegal to change out the OEM Cat. on OBDII in California unless it quit working. I don't konow how you'd get caught though as I've never seen the Smog Check guys look under the car.
We do have nice weather though!
Old Jan 22, 2004 | 12:03 PM
SKDRCR's Avatar
Default Re: (dblair)
What about a carsound cat,
are those legal in ca?
jdium
Dec 23, 2006 11:59 AM
nuezdaman44
Mar 13, 2006 09:57 PM
hlee5363
Dec 13, 2005 11:50 AM
allentxlude
Feb 17, 2005 07:37 AM
ntegls
Aug 13, 2003 04:51 PM
