do i need a cat ???
Old Dec 8, 2005 | 05:01 AM
hlee5363's Avatar
Default do i need a cat ???
i just bought a header for my car and it was too long to put my cat on... so i was running open header for couple of days.. then it got annoying so i put it in to a local shop.. and ask them to put a pipe between so it becomes quieter... and i was trying to fix my check engine light .. it wont go away... i have a friend with a ek with an gsr motor.. with no cat and he has no check engine light... so i was just wondering if i need a cat to get my check engine light off .... oh yea by the way when i was installing my header... instead of taking the o2 sensor off through the bracket.. i pulled the wires out of them.. and i didnt knoe that they go in a certain place so i just put them on whatever way... so my question is... do i need a cat or do i need new o2 sensors... the o2 sensors are right now.... but check engine light is still on.... so let me knoe whta u guys think...
Old Dec 8, 2005 | 05:35 AM
Racermech's Avatar
Default Re: do i need a cat ??? (hlee5363)
Yes you need a cat, they are cute and fuzzy!!! O wait you are talking about your car......
Yes you need a cat. The second O2 sensor will cause the car to throw a code because it is either not hooked up, ot it is reading levels that are too high. When you say you pulled the wires out do you mean you actually just yanked them out of the sensor?? If you did that it sounds like you will have to replace that sensor also.
Old Dec 8, 2005 | 05:52 AM
HONDA RR's Avatar
Nope you don't need a cat. Take it off asap.
Old Dec 8, 2005 | 12:01 PM
hlee5363's Avatar
its been off and yea... i yanked it off but i took it to a muffler shop and they said they fixed it and put it back ont he right spots... but cel is still on.. and wont go away...
Old Dec 8, 2005 | 12:02 PM
temp's Avatar
do you think you could handle the responsiblity of owning a cat?
Old Dec 8, 2005 | 03:31 PM
.Kevin.'s Avatar
Default Re: do i need a cat ??? (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hlee5363 &raquo;</TD></TR><TR><TD CLASS="quote">its been off and yea... i yanked it off but i took it to a muffler shop and they said they fixed it and put it back ont he right spots... but cel is still on.. and wont go away...</TD></TR></TABLE>
check the wires you pulled out of the 02 sensor that was my problem the conection was not good enough, unplug it, and then take neeedle nose plyers and pull the little clips though the plug.
Old Dec 8, 2005 | 03:54 PM
BrooX's Avatar
Default Re: do i need a cat ??? (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">Yes you need a cat, they are cute and fuzzy!!! O wait you are talking about your car......
Before I came in here, I knew someone was going to post something like that. lol.
Old Dec 8, 2005 | 03:55 PM
ITB
Guest
Posts: n/a
to get rid of the CEL you need all the o2 sensors hooked up. if you have no where you put them wrap it with aluminum foil and put it somewhere safe. your cel will then go away
Old Dec 8, 2005 | 03:57 PM
temp's Avatar
Default Re: (ITB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITB &raquo;</TD></TR><TR><TD CLASS="quote">to get rid of the CEL you need all the o2 sensors hooked up. if you have no where you put them wrap it with aluminum foil and put it somewhere safe. your cel will then go away</TD></TR></TABLE>
everytime i see your name i think "IN THE BUTT"
Old Dec 8, 2005 | 10:24 PM
watsvtecEK's Avatar
Default Re: (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">everytime i see your name i think "IN THE BUTT" </TD></TR></TABLE>
first off TEMP u can go F yourself
hehe
Old Dec 9, 2005 | 10:39 AM
yee SERIOUS's Avatar
just go OBD1 and baam! no more CEL or do what ITB said with the foil and hiding the secondary o2. (i'm assuming you have an obd2 car)
Old Dec 9, 2005 | 01:06 PM
BrooX's Avatar
Default Re: (temp)
bwahahahahahahahahahaha. Me too Wait a second Temp, lets not let things get wierd now
Old Dec 12, 2005 | 08:15 AM
temp's Avatar
Default Re: (D 2da A9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">
hehe</TD></TR></TABLE>
tee hee
Old Dec 12, 2005 | 08:16 AM
temp's Avatar
Default Re: (DA9GUY-637)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9GUY-637 &raquo;</TD></TR><TR><TD CLASS="quote">
bwahahahahahahahahahaha. Me too Wait a second Temp, lets not let things get wierd now </TD></TR></TABLE>
buahahah
*long ackward silence*
Old Dec 12, 2005 | 08:18 AM
no2unenolife's Avatar
Default Re: (ITB)
been doin this for a long time
Old Dec 13, 2005 | 11:50 AM
hlee5363's Avatar
but then im screwed for emissions...
hymn
Feb 1, 2013 02:58 PM
silentdeath12886
Feb 13, 2007 11:43 AM
Melman872
Nov 29, 2005 08:54 AM
dmckrazy45
Jun 1, 2005 07:23 AM
Seedc2
Jul 23, 2003 11:20 AM
