Tachometer Install... please HELP... thanks!
Old Jan 20, 2004 | 11:10 AM
Drum_Guru's Avatar
Default Tachometer Install... please HELP... thanks!
I just bought an autometer Cobalt Tach. for my 98 Prelude and I am planning on installing it soon... this is going to be really easy, except for the wiring... it has 4 wires that need to be connected...
1. WHITE-to-12v dash lighting, which wire do I use, and how do I get to it? I installed some aftermarket guage faces, so the factory dimmer is now bypassed... where should I look?
2. RED-to-12v igniton switch, once again, which wire do I use, and how do I get to it? Do I just pull off the steering collumn cover and spllice this into the wire that goes to the ignition switch? Also, if I get one of those Ignited push-button ignitions, do I just splice in those wires to the ignition switch also? And most importantly, will it all work with the immobilizer system? (Im pretty shure it should...)
3. BLACK-to-"good engine ground", can I use any ground under the hood or does it have to be on the engine? ... how about my batter to chasis ground spot?
4. GREEN-to-ignition coil (- lead), I got that one covered... heh...
Alright... thanks in advance for your help!!
Travis.
Old Jan 20, 2004 | 11:50 AM
rsbad454's Avatar
Default Re: Tachometer Install... please HELP... thanks! (Drum_Guru)
id say search................
EH3 JR
Apr 27, 2009 04:43 PM
Lucky-13
10
Mar 14, 2007 02:45 AM
Drum_Guru
Jan 21, 2004 06:33 PM
hybridreams
Aug 10, 2003 06:22 PM
S13 slide
Jan 12, 2002 06:28 PM
