launching
in a prelude si i can beat my friends type-r off the line most of the time, otherwise its even, itr is suposed to be faster 0-60, what do you itr owners launch at. he wants to know if its his driving.
we checked it out, and the r wheel spins then pauses then hits the v-tech. it seems to bog down for a sec then grips into the v-tech. anything above 4 seems to just wheel spin too much, what kind of tires do you use?
i got best 1/4 and trap speed results with stock tire pressure launching @ 3,800 while feathering
however, i got better 60' times with 23 psi front tire pressure...so i guess finding the balance between too high and too low psi is key
and stock tires.
[/quote]we checked it out, and the r wheel spins then pauses then hits the v-tech. it seems to bog down for a sec then grips into the v-tech. anything above 4 seems to just wheel spin too much, what kind of tires do you use?[/quote]
bro you need to take a look under your hood sometime
