launching
Old Oct 2, 2001 | 12:10 AM
4thgenturboSi's Avatar
New User
Default launching
in a prelude si i can beat my friends type-r off the line most of the time, otherwise its even, itr is suposed to be faster 0-60, what do you itr owners launch at. he wants to know if its his driving.
Old Oct 2, 2001 | 12:15 AM
Louie's Avatar
What would Chente do?
Default Re: launching (4thgenturboSi)
on a track, most say between 3.5 -4.5k rpm. with a feathering of clutch.
Remember though the si has more torque and is easier to get going.
Old Oct 2, 2001 | 01:07 AM
New User
Default Re: launching (vagoITR)
we checked it out, and the r wheel spins then pauses then hits the v-tech. it seems to bog down for a sec then grips into the v-tech. anything above 4 seems to just wheel spin too much, what kind of tires do you use?
Old Oct 2, 2001 | 04:14 PM
gmsu00's Avatar
New User
which RPM...???
let's post which rpm you guys let clutch go...or juss dump it???
Old Oct 2, 2001 | 04:16 PM
Big Phat R's Avatar
Use lower tire pressures for the Type R and launch at a higher RPM.
Old Oct 2, 2001 | 05:02 PM
Toda Party's Avatar
Default Re: launching (Big Phat R)
i got best 1/4 and trap speed results with stock tire pressure launching @ 3,800 while feathering
however, i got better 60' times with 23 psi front tire pressure...so i guess finding the balance between too high and too low psi is key
Old Oct 2, 2001 | 05:55 PM
B2FiNiTY's Avatar
VTEC and stock tires.
Old Oct 2, 2001 | 05:57 PM
Type Goch's Avatar
New User
[/quote]we checked it out, and the r wheel spins then pauses then hits the v-tech. it seems to bog down for a sec then grips into the v-tech. anything above 4 seems to just wheel spin too much, what kind of tires do you use?[/quote]
bro you need to take a look under your hood sometime
Old Oct 3, 2001 | 01:21 PM
SiN.DC2R's Avatar
Default Re: launching (Type Goch)
_______
hahah~
1SLOWlsTEG
Oct 3, 2004 05:18 PM
oMek
Aug 10, 2003 09:32 PM
toooslow
May 3, 2003 11:48 AM
2001TypeR
Jul 30, 2002 07:56 PM
01ITR#700
Jul 26, 2001 05:36 PM
