H23A1 rod and crank bearing color codes...
don't really know... All i know is tha ti have bent two different rods in two different motors. I know that mine is a weird almost purple color but that could be heat damage cause i didn't know that i had an oil leak and was redline way to much with little oil and it bent the rod or burnt out the bearings. I am tearing the motor down and getting the cranshaft measured to see if it is bent or if the bearings are shot. Dam motor only has 30,000 on it.
