Need Help Ls Motors, knock knock
Ok well this is the 3rd motor i put in and got it running friday night . Yesterday i was fixing some idle issuses and a coolant leak anyway we drove it around my subdivision about 4-5 times and pulled back in to adjust the idle control screw and it started knocking . I talked to a freind at the shop where i got this motor and he said since this has happend 3 times now he thinks that my engine wiring harness might have a bad wire .
Also when i bought the car it spun bearings the guy (chris) i bought the car from said he was just driving and the oil light came on and the car died and then he started it and it started knocking . Well that motor i took apart and it spun 2 rod bearings .
but anyway have you heard of this or do you think that it is possible that this is what could be causing me problems.
also i found out that the ecu has been chiped by Gude . he said that the rev limiter was changed . ?????????????
its really hard to make sense out of your story
when you bought the car it had 2 spun bearings.
now you placed another engine in there and its backfiring so you are
afraid that the new engine will spin another bearing since it happened
more than 3 times with the same car.
to begin you should change the ecu since gude has a bad rep.
no no no
sorry i should of been more clear
i have put 3 motors in the car since i bought the car . all three of the motors have started knocking the day after i put them in . it does not back fire .
the oil light comes on when i slow down to a stop . it is random when the light comes on .
EFin' Kyle
10
Feb 24, 2007 08:33 PM
[626]95-GSR
Aug 21, 2003 02:34 AM
