4th gen making wierd clicking noise whatn turning?
Old Jan 19, 2004 | 03:56 PM
superturboprelude's Avatar
Default 4th gen making wierd clicking noise whatn turning?
i have a prelude 1992 4th gen and when i turn my car makes a wierd clicking noise what can it be help me
Old Jan 19, 2004 | 03:59 PM
britishlude's Avatar
Default Re: 4th gen making wierd clicking noise whatn turning? (superjunprelude)
CV joint on it's way out ? does it only happen when turning one way ?
Old Jan 19, 2004 | 04:00 PM
caz245's Avatar
Does it make clicking noise when you turn right or Left? If it only makes a clicking noise turning one direction then the cv joint on that side is probably shot , if it clicks in both directions either both cv joints are shot or you have something rubbing somewhere maybe.
Old Jan 19, 2004 | 08:06 PM
Blackhorse6's Avatar
Default Re: 4th gen making wierd clicking noise whatn turning? (jz)
agreed CV joint. Bummer
Old Jan 19, 2004 | 08:28 PM
H22A EG6's Avatar
Default Re: 4th gen making wierd clicking noise whatn turning? (Blackhorse6)
yup got same prob dude
Old Jan 19, 2004 | 10:52 PM
VTECRaZeR's Avatar
Default Re: 4th gen making wierd clicking noise whatn turning? (H22A EG6)
My left front wheel has like a jumping effect when I turn right. It's almost like it wants to skid... Could this be a problem from lowering and may be a camber kit could fix it?
I just had an accident on that left front wheel and had to replace the cradle and the lower control arm... could it be something alse is bent....?
I got an alignment on it btw and they said that side passed but my right side needs a camber kit...
any help would be cool
PMs be good
Old Jan 19, 2004 | 11:04 PM
Matgallis's Avatar
Default Re: 4th gen making wierd clicking noise whatn turning? (VTECRaZeR)
i would say a tire rod
Old Jan 19, 2004 | 11:27 PM
Default Re: 4th gen making wierd clicking noise whatn turning? (Matgallis)
today i look under my car and the cv boots to my steerin rod or tie rod what ever you call it is ripped could this be the problem the torn cv boot is locat ont eh driver side and can this be replaced
Old Jan 19, 2004 | 11:28 PM
@ries's Avatar
Yes it can... doesn't usually take that long either.
Old Jan 19, 2004 | 11:30 PM
Shakes's Avatar
space cadet
just replace the whole shaft man. its not worth fixing. get a fresh one and be set.
yes, that thing is shot.
Old Jan 20, 2004 | 12:44 AM
Default Re: 4th gen making wierd clicking noise whatn turning? (shakes)
ITS MY TIE ROD CV BOOT THAT IS RIPPED NOT MY AXLES [PLEASE HELP MEEEEE
Old Jan 20, 2004 | 01:08 AM
Shakes's Avatar
space cadet
can you take a pic for us.
Old Jan 20, 2004 | 01:13 PM
Honda Sport's Avatar
sounds like a bad axle(CV joints) to me. either replace your axle or pull your old axles and clean them out and put on a new boot. then apply new CV grease and it should be fine. Unless your bearings inside the joint are bad, replace the axle.
aZnAcCoRd02
Oct 29, 2005 10:53 AM
rudeman85
Nov 4, 2004 01:19 PM
chrisw
Mar 26, 2004 08:07 AM
tossnupweight
Nov 10, 2003 01:13 PM
