ITR TEIN flex fit on an EF?
Old Jan 19, 2004 | 01:53 PM
red civic standard's Avatar
Default ITR TEIN flex fit on an EF?
http://www.tein.com/flexdamp.html
Will the ITR Tein Flex damper kit fit on an EF?
I am pretty sure that the rear will bolt right up using 88 CRX control arms or ITR control arms. I believe that the front damper is much taller than the stock EF strut, but can be used with the correct fork. I believe you can use an ITR fork or the 92-95 Civic fork.
Can anyone confirm any of this?
Old Jan 19, 2004 | 03:54 PM
bryant's Avatar
Default Re: ITR TEIN flex fit on an EF? (red civic standard)
You are correct. You need 88/ITR rear LCA's and either EG or DC front forks. And the shocks are longer then EF's
Old Jan 19, 2004 | 04:03 PM
EG8R's Avatar
Default Re: ITR TEIN flex fit on an EF? (Bryant)
I too will back this up. I've done it to my car.
Old Jan 19, 2004 | 06:08 PM
Default Re: ITR TEIN flex fit on an EF? (skelly ed6)
did you notice that the front rode too high?
or was the ride height ok with the correct fork?
RED_90TEG
Dec 20, 2007 12:15 PM
whole9
Feb 28, 2005 04:02 AM
hatchlessrex
Jul 12, 2004 03:06 PM
lsvteceg
Nov 11, 2002 05:24 PM
ITR764
10
Oct 7, 2002 04:59 PM
