need help, vtec running really weak...
Old Jan 19, 2004 | 12:47 PM
PlikityPLAH's Avatar
Default need help, vtec running really weak...
recentley i have noticed that my vtec had been running really weak, like not that much of a kick as it had a week ago, i have just put more oil in and still nothing, any ideas??
Old Jan 19, 2004 | 12:53 PM
Mires's Avatar
Default Re: need help, vtec running really weak... (PlikityPLAH)
How much oil did you put in it? If it was really low it might not have been enough.
RGoose18's Avatar
Most of the time it's your oil level or just psychological. Check your oil again and if it's fine, forget about it.
Old Jan 19, 2004 | 01:11 PM
it was pretty low, like below that bottom hole, then i filled it to about the top hole
Old Jan 19, 2004 | 01:22 PM
r573's Avatar
Default Re: (PlikityPLAH)
Your best bet is to do an oil change
Old Jan 20, 2004 | 07:32 AM
4U2NV's Avatar
Default Re: (r573)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r573 &raquo;</TD></TR><TR><TD CLASS="quote">Your best bet is to do an oil change </TD></TR></TABLE>
Also, check your VTEC solenoid screens... There should be two of them, upper and lower... They may be clogged, thus straining the system to get enough oil pressure for VTEC engagement...
Old Oct 3, 2004 | 07:01 PM
oerski's Avatar
Default Re: (4U2NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">
Also, check your VTEC solenoid screens... There should be two of them, upper and lower... They may be clogged, thus straining the system to get enough oil pressure for VTEC engagement... </TD></TR></TABLE>
Would this still have the sound of vtec engaging but a drop in power???? cuz that is what mine is doing....
tigasin
Nov 14, 2008 11:58 PM
tuan...
May 7, 2008 12:09 PM
Ryan.
Oct 12, 2005 09:11 AM
itr1235
Oct 12, 2004 10:56 PM
1boostedgsr
Aug 4, 2004 03:21 PM
