Post-Swap NO START- HELP
Old Jan 18, 2004 | 07:12 PM
meams's Avatar
Default Post-Swap NO START- HELP
ok, i swapped a built 00' D16y8 into my 98 Civic...
I used my stock D16y5 Wiring harness...from my 98 HX, and a P2P ECU from a 97 civic EX...we swapped the motor in, wired her up, and it wont start...it turns over but we're getting no spark.
There are two plugs/sensors/whatevers left over on the wiring harness with nowhere left to go....can this all be fixed by getting a OBD2-A harness?
What would you all reccomend?
Thanks
-Tom.
Old Jan 18, 2004 | 07:14 PM
meams's Avatar
Default Re: Post-Swap NO START- HELP (meams)
oh, and my friend who pretty much did all the work told me to add taht my stock d16y5 harness doesnt have a sensor for the knock on there, but the harness i got with the d16y8 did....
P.S. we didnt use the harness that came with the D16y8 becuase it didnt plug up to ANY of my ECUs.
Old Jan 18, 2004 | 07:16 PM
azrakain's Avatar
I'm the co-installer. I'll try to answer any questions I can, but I'm not a honda guy
Old Jan 19, 2004 | 02:32 AM
meams's Avatar
Default Re: Post-Swap NO START- HELP (azrakain)
bump. i need help.
Old Jan 19, 2004 | 07:02 AM
azrakain's Avatar
I guess no one has any ideas.
Old Jan 19, 2004 | 08:56 AM
b20turbojason's Avatar
what distributor did you use. they could be differant
Old Jan 19, 2004 | 09:36 AM
meams's Avatar
Default Re: Post-Swap NO START- HELP (b20turbojason)
i went to switch out the distributors..and the plugs coming off the distributor htat plugs into the wiring harness are different...
therefore im led to assume that:
Since the plugs from the distributor are different, the distributor itself is different...and since its different it won't work on tihs engine, and thus since i cant swap them out since the plug from the harness wont fit hte plug on the other distributor...i must buy a new harness...im on my way to honda...i dont really care about the $ i just want everything to work right.
Old Jan 19, 2004 | 11:32 AM
azrakain's Avatar
tom, did you find out about that knock sensor? find out how much it is.
Old Jan 19, 2004 | 06:31 PM
meams's Avatar
find out what about it...the harness doesnt have a plug for it.
Hey everyone...why doesnt my d16y5 harness have a plug for a knock sensor?
Ladolcettad
Dec 13, 2011 07:32 PM
justinwazner
10
Oct 27, 2010 06:29 PM
Christian_D
Sep 26, 2008 06:31 PM
guedo148
Jun 14, 2007 11:12 AM
93civicjaydm
Nov 10, 2006 11:36 AM
