An eg won't start, HELP!!!!!!!!!!!!!!!!!
Old Jan 18, 2004 | 10:52 AM
RedRex8's Avatar
Default An eg won't start, HELP!!!!!!!!!!!!!!!!!
My friend's car, 95 civic hatch, isn't getting any juice, but everything checked is making power starter, fuses in the fuse box, battery (new everlast). THe only thing that works is the hazards and the brake lights. the car can't even be jumped, are their any experts out there to help a buddy out.
a future thanks and an internet cookie for someone that can help
Old Jan 18, 2004 | 11:07 AM
Kendall's Avatar
Not getting any juice as in, the motor isn't turning over, you just turn the key and nothing happens?
Old Jan 18, 2004 | 12:10 PM
RedRex8's Avatar
Default Re: (Kendall)
as in nothing is happening and the only thing that is working is the brake lights, horn, and hazards, but everything else is nothing. I have checked everything all the grounds and they all coming out with 12 volts, wondering what i can do to get the car to at least get the headlights, and interior lights to come on. I turned the key and nothing happens.
Old Jan 19, 2004 | 09:08 AM
sleeperek's Avatar
Default Re: (RedRex8)
WAIT A MINUTE........YOU CHECK THE GROUNDS AND YOUR'RE GETTING 12 VOLTS....YOU SHOULD BE GETTING 0 VOLTS...YOU MIGHT HAVE THE GROUND REVERSED.....GET A VOLT METER AND CHECK YOUR CHASIS IF THEIRS ANY VOLTAGE ON IT....IT SHOULD BE 0 VOLTS....BUT CHECK THE GROUND FROM THE ENGINE TO THE MOTOR....THEIR SHOULD BE AT LEAST 2 GROUND POINTS ON YOUR EG....FROM RADIATOR SUPPORT TO THE HEAD...AND FROM THE FRAME (PASSENGER SIDE) TO THE TRANNY....CHECK THESE GROUND POINTS....LET ME KNOW IF THIS WORKS
Old Jan 19, 2004 | 12:20 PM
Jimmy's Avatar
Global Moderator
Default Re: (sleeperek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperek &raquo;</TD></TR><TR><TD CLASS="quote">WAIT A MINUTE........YOU CHECK THE GROUNDS AND YOUR'RE GETTING 12 VOLTS....YOU SHOULD BE GETTING 0 VOLTS...YOU MIGHT HAVE THE GROUND REVERSED.....GET A VOLT METER AND CHECK YOUR CHASIS IF THEIRS ANY VOLTAGE ON IT....IT SHOULD BE 0 VOLTS....BUT CHECK THE GROUND FROM THE ENGINE TO THE MOTOR....THEIR SHOULD BE AT LEAST 2 GROUND POINTS ON YOUR EG....FROM RADIATOR SUPPORT TO THE HEAD...AND FROM THE FRAME (PASSENGER SIDE) TO THE TRANNY....CHECK THESE GROUND POINTS....LET ME KNOW IF THIS WORKS</TD></TR></TABLE>
caps lock is your friend eeh? ;-\
Old Jan 19, 2004 | 06:45 PM
sirminder's Avatar
Default Re: (USDMDC2)
What ever the problem is, be sure to diagnose it well. Then think of how to make that a kill switch.
oldmanofsactoCA
Honda CR-V & Element
Mar 25, 2017 02:46 PM
dgmills89
Honda Civic (2006 - 2015)
May 2, 2015 01:48 PM
DO/\/\O
Jan 27, 2012 12:50 AM
king_mo
Dec 2, 2008 06:11 PM
RedRex8
13
Jan 19, 2004 01:49 PM
