tire size?
you may have rubbing issues, particularly in the front, with 215/45s depending on your drop (if you are lowered).
i have 215/40s w/ a prokit drop (1.4~1.5inch) and had a minor rubbing issue with front right. but fixed easily by cutting the inner fender liner a lil bit.
try to get close to the +55 as you can regardless of whether you are dropped or not.
5 X 114.3
my z5000 wheels are 17 X 7. you may or may not have rubbing issues. it's pretty much case-by-case thing, imo.
just be sure to align the car properly after you lower the vehicle. and invest into camber kits if necessary.
