How can you tell the difference between a AUTO y8 mani and a y8 STD mani?
Old Jan 17, 2004 | 06:14 PM
Wes90civic's Avatar
Default How can you tell the difference between a AUTO y8 mani and a y8 STD mani?
Im buying a y8 mani and i was wondering how you can tell if its off of a automatic or a standard. Also does it make a difference which kind it is, it will still work on my y8 head swap right, or is one better than the other? I dont mean to sound dumb im just didnt know if there was a differnce, im sure there probably isnt besides a sensor or something. Well any info will help, thanks.
Old Jan 17, 2004 | 06:27 PM
jdmdelsol's Avatar
Default Re: How can you tell the difference between a AUTO y8 mani and a y8 STD mani? (Wes90civic)
The Y8 manual manifold has the mount for the IACV and hte AUTO does not, they are filled.
Old Jan 17, 2004 | 06:29 PM
dsadas89das78934's Avatar
Default Re: How can you tell the difference between a AUTO y8 mani and a y8 STD mani? (jdmdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdelsol &raquo;</TD></TR><TR><TD CLASS="quote">The Y8 manual manifold has the mount for the IACV and hte AUTO does not, they are filled.</TD></TR></TABLE>
pretty much....
Old Jan 17, 2004 | 06:35 PM
Wes90civic's Avatar
Well can it be tapped out to make the sensor fit on the mani? or do i have to mount it on the intake? Is it worth the time if i can get it cheap or just look for a standard one? thanks guys
Old Jan 17, 2004 | 06:38 PM
b20_ed's Avatar
Default Re: (Wes90civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes90civic &raquo;</TD></TR><TR><TD CLASS="quote">Well can it be tapped out to make the sensor fit on the mani? or do i have to mount it on the intake? Is it worth the time if i can get it cheap or just look for a standard one? thanks guys</TD></TR></TABLE>
um no. Cause the IACV is like awkward looking and sure as hell wouldnt fit on an intake. It wouldnt even function like it would on an Intake Manifold. And you cant just tap out to make a sensor fit.
Old Jan 17, 2004 | 06:51 PM
illicon2003
Guest
Posts: n/a
pretty sure the IM for manual is 2.75 as opposed to the auto's 2.5..not 100%
Old Jan 17, 2004 | 07:33 PM
Default Re: (illicon2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illicon2003 &raquo;</TD></TR><TR><TD CLASS="quote">pretty sure the IM for manual is 2.75 as opposed to the auto's 2.5..not 100%</TD></TR></TABLE>
what are you talking about?
Old Jan 17, 2004 | 10:56 PM
Wes90civic's Avatar
Well if a auto y8 mani has the spot where the IACV sensor goes but it just flat with no holes, cant i just make the hole, and thread some screw holes and mount it? It would be in the same spot so it should work the same right? Anyways maybe im dumb but i thought that might work.
Old Jan 18, 2004 | 12:20 PM
civic97b18csi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes90civic &raquo;</TD></TR><TR><TD CLASS="quote">Well if a auto y8 mani has the spot where the IACV sensor goes but it just flat with no holes, cant i just make the hole, and thread some screw holes and mount it? It would be in the same spot so it should work the same right? Anyways maybe im dumb but i thought that might work.</TD></TR></TABLE>
I wanted to know the same thing.
Old Jan 18, 2004 | 12:22 PM
Smith Wise's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccaian &raquo;</TD></TR><TR><TD CLASS="quote">what are you talking about?</TD></TR></TABLE>
let me find some pics of both.... brb
Old Jan 18, 2004 | 12:35 PM
Smith Wise's Avatar
Default Re: (Jswpstdoff)
Manual with y7 TB with the IACV
Best pic I have of an auto y8, this is 99-00 with air injection, thus the extra nipples
the IACV is hidden in that pic, but here is what it is... in the same position, mounted on the TB like all y7 IMs and all auto y8 IMs
another bad pic, but that's it with the coolant lines attached
84dime
Dec 15, 2010 07:36 AM
jdejesus3
Oct 1, 2007 05:34 PM
clockstick
Aug 14, 2006 05:55 PM
tylerdurden
Jan 31, 2003 11:50 AM
