my shifter has too much play!!
Old Jan 17, 2004 | 05:03 PM
ironchef25's Avatar
Default my shifter has too much play!!
um. my shifter has to much play even though its on a gear! how can i fix this?? i want it so that when its on a gear theres minimal play.. is there like a thing i need to tighten or something?? also my car is a 88crxhf
Old Jan 17, 2004 | 05:15 PM
sporkcrx's Avatar
Default Re: my shifter has too much play!! (ironchef25)
Mine is the same way. I have the ES shifter bushings too and they didn't do much, if anything at all.
Old Jan 17, 2004 | 05:26 PM
RCautoworks's Avatar
https://honda-tech.com/zerothread?id=563939
Old Jan 17, 2004 | 09:23 PM
b16_madman's Avatar
Default Re: my shifter has too much play!! (90blackcrx)
< same here. I drive my gf's 98 ex w/the poly bushings, or my buds 2k integra and I hop in mine and im just having to become accumtomed to the slop.
Is there another way around this? b/c at first when i did the shifter bushings it was nice and tight.
Old Jan 17, 2004 | 09:54 PM
ComposiMo's Avatar
We still do this modification... if you are interested in it, please contact me at ComposiMo@RPIracing.com. its a bit expensive, but that is because the joint we use is extremely expensive.
But it is worth it
By the way, if you were doing a swap at the same time, and provided the linkage from a 90-91 'teg, we'd be able to do the shortening at the same time, and it wouldn't cost much more at all, since we basically have to do a bit of cutting anyway....
Old Jan 18, 2004 | 06:05 AM
Cory man's Avatar
Default Re: my shifter has too much play!! (ComposiMo)
If you have a stock shifter rod then the bottom bushing is probably worn. It happened in my old crx and hb and replacing the shifter rod fixed the problem. The bushing that connects the rod to the linkage starts to have excessive slop making your shifter move around excessively in and out of gear. HTH
Old Jan 18, 2004 | 06:11 AM
89civicdx's Avatar
Default Re: my shifter has too much play!! (Cory man)
grab your shifter and try rotating it in the upright position ..as in can you turn it clockwise and counterclock wise a bit ?then that means the shifter rod bushing is fubared and you need a new one. Buying the ES kit won't help that.
The shifter bushing is located in the bottom of the actual shifter.
Old Jan 18, 2004 | 07:16 AM
HT Chaplain's Avatar
Loved
[QUOTE=ComposiMo]We still do this modification... if you are interested in it, please contact me at ComposiMo@RPIracing.com. its a bit expensive, but that is because the joint we use is extremely expensive.
But it is worth it
is it still $175
Old Jan 18, 2004 | 07:43 AM
ComposiMo's Avatar
Default Re: my shifter has too much play!! (legutki)
Yes, it is still $175 (plus shipping of course).... Let me know if you want this done. We've done quite a few of these over the course of the last few months, but they've all been local, and i don't think that any of the people i've done this for are on this board (could be wrong), but i may be willing to give a lower price to someone on this board, just to have someone from here to vouch for how good it makes the shifter feel.. hehe
Old Jan 18, 2004 | 09:37 AM
b16_madman's Avatar
I've got a B&M shifter, stock ****, and the ES shifter bushings.
I've got a little play while it's in gear, but also I can push the shifter down so it hits the exhaust pipe.
I think either the piece that holds the bushing on the shifting rod is loose, or can the ES bushings shrink?
I haven't been able to check it out yet.
ComposiMo. If I get this joint, could you do up a rod for me, and I send you the core back in? b/c I can't be out of my car.
Old Jan 19, 2004 | 07:19 AM
ComposiMo's Avatar
Default Re: my shifter has too much play!! (B16_madman)
Hey there... yea, i can do that. Contact me via Email (ComposiMo@RPIracing.com) and we can discuss the details
jb0705
Jul 10, 2009 12:39 PM
00civicsiboy
Mar 22, 2009 06:41 PM
jokerstone
Aug 6, 2007 04:21 PM
blackhope121
Mar 21, 2007 06:33 AM
globe
May 6, 2002 01:24 AM
